  • Replies 37
  • Member For: 19y 5m 14d
Unless you have the in/outlet in the middle or huge tanks no intercooler will efficiently perform at the furthest point away from the in/outlet. This is generally why 300mm is the largest common size, To go larger ie 400 you do not get the same effect of cooling for the surface area gained.
It takes a lot of work to fit that size cooler in, looks great.
  • <put funny sh*t here>
  • Member For: 18y 5m 27d
Looks great dude. Got any pics with the front bumper back on? Is there any overhang underneath the bumper and can you see the top part of the cooler through the top grille (where the ford badge is)?
  • Member For: 18y 11m 15d
Yes the tanks are tight at the top section, but unfortunatly we dont have all that much room to play with without going to extremes with the angle grinder...
Its still too low so I will move it up an inch so the under guard fits better and doesnt bulge down. Once the core moves up it will be very close to the headlights so larger tanks wont fit.
Sure its not perfect, but its a zillion times better than stock and didnt cost a grand.
I got it from the states via yahoo auctions, Ive serched for ages to find something this size but unfortunatly we dont see them in Oz too often
  • Team Bute
  • Member For: 21y 9m 20d
Seeing as the end tanks are very tight at the top, it can be expected that there will be reduced flow through that section.
Given also, that the bumper assembly occludes direct air onto the centre section of the IC, you also get reduced effectiveness if you raise the IC.
You might find that you will get better measurable efficiency by modifying the guard panel underneath to allow the IC to get as much of it's surface exposed in the bottom sector of the grille opening, as that is where the majority of the air will flow.
just a thought.
tom
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 19y 1d
That cooler looks awsome mate, good work. :spoton:
And dont you just hate the :spoton: air con line it stoped me from getting a bigger cooler.
  • Member For: 18y 7m 25d
why dont ya cut off the front bumper mount (the metal bit across the front )
cause that thing does bugger all my mate is a panel beater and they chop those things of all the time .
trust me if u were in a crash the front ends gonna bust no matter wat
Dont think my insurance company would like that
Isnt that apart of the chassi, so technically if you cut it with out a engineer certificate it would be a write off. TECHNICALLY (if that's right ???)
  • Big Gun
  • Member For: 22y 6m 25d
He doesn't run Bogans-R-Us does he?
