  • Member For: 20y 6m 7d
Posted
Gday Guys,
I removed the centre muffler the other day and now sometimes when when I accelerate, generally before I hit boost, I get a splutter like its either getting too much fuel or its starving of fuel. Either way I cant accelerate until I back off and try again. Doesnt do it all the time just every now and then.
Im guessing that because I have removed the centre muffler it has less restriction.
Iknow I have an overboost problem since I put the bigger cooler, K&N etc.. so would this problem be related to overboosting? Will an edit/tune fix the problem?
Cheers
  • role model
  • Member For: 20y 6m 28d
Posted
Possible that your car is about to go into limp mode or the factory
ECU doesnt no whats going on but in saying that I wouldnt think
by removing the centre muffler it would unrestric anything as that
not restricted part of the exhaust but you also have a cooler and k&n
I would very much say you need a edit ahahah.
  • Member of team Kittens
  • Member For: 22y 7m 15d
Posted
:pinch:
More over - if you don't get it done soon you run some very serious risks of damaging your car.
what you have done NEEDS a tune to make is safe...
I would suggest you find a good tuner and get a custom tune ASAP
good luck - and stop give it to it until you get a tune - in fact I would not drive the car...
Cheers, :pinch:
Ben.
  • role model
Posted
Which state are you in JET4CE??
  • Formerly Turbo6
  • Legacy Donating Member
  • Member For: 23y 9m
Posted
Plug gaps mate - make sure they are .7 all round.
