F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 6m 24d Gender: Male Location: Strapped in and holding on Posted 15/09/06 11:32 AM Author Share Posted 15/09/06 11:32 AM Bearings failed in the old one, hence the buggered wheels..Yeah, huffer is a wog special.. ?? Link to comment https://www.fordxr6turbo.com/forum/topic/28537-new-turbo-installed/page/2/#findComment-436196 Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 7m 9d Gender: Male Location: Brisbane Posted 15/09/06 11:36 AM Share Posted 15/09/06 11:36 AM Sounds like you might better your time down the 1/4 now. Link to comment https://www.fordxr6turbo.com/forum/topic/28537-new-turbo-installed/page/2/#findComment-436203 Share on other sites More sharing options...
SavageF6 Donating Members 1,622 Member For: 21y 2m 20d Gender: Male Location: Sydney Posted 15/09/06 01:21 PM Share Posted 15/09/06 01:21 PM Nice Ben, nice Link to comment https://www.fordxr6turbo.com/forum/topic/28537-new-turbo-installed/page/2/#findComment-436301 Share on other sites More sharing options...
MYWPN Donating Members 554 Member For: 20y 8d Gender: Male Location: Bendigo Posted 15/09/06 01:41 PM Share Posted 15/09/06 01:41 PM nice turbo, would'nt mond that hanging from the side of my ute :yumyum: Link to comment https://www.fordxr6turbo.com/forum/topic/28537-new-turbo-installed/page/2/#findComment-436303 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 6m 24d Gender: Male Location: Strapped in and holding on Posted 15/09/06 04:02 PM Author Share Posted 15/09/06 04:02 PM Did you go for a bigger compressor wheel, so the same as stock just with a 0.7 AR compressor cover ?I fitted a bigger 66mm comp wheel (vs stock 61 mm), and while it produces more kW it results in about 500rpm in additional lag.CheersRobin.←To the best of my knowledge, it's the 66mm wheel. I really don't want to induce more lag, but with increased efficiency to the the whole intake tract, the turbo will only have to boost to say 17-18 psi to achieve full manifold pressure and desired power level ( I hope ), instead of 25 psi +. Lag times should be reduced I hope, along with intake temps, and hence achieve my power levels easily.. I'm only chasing slightly more power than I had, with the new turb having to do less work to provide it. Link to comment https://www.fordxr6turbo.com/forum/topic/28537-new-turbo-installed/page/2/#findComment-436329 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 14d Gender: Male Location: Brisbane Posted 16/09/06 12:45 AM Share Posted 16/09/06 12:45 AM I'm only chasing slightly more power than I had, with the new turb having to do less work to provide it.←.....for the time being anyway! Until the camel catches up again. Link to comment https://www.fordxr6turbo.com/forum/topic/28537-new-turbo-installed/page/2/#findComment-436372 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 6m 24d Gender: Male Location: Strapped in and holding on Posted 16/09/06 01:05 AM Author Share Posted 16/09/06 01:05 AM I'm only chasing slightly more power than I had, with the new turb having to do less work to provide it.←.....for the time being anyway! Until the camel catches up again.←Thanks Tabitha, As far as that retched yellow thing goes, it will always have the upper hand, As soon as the edit s/ware comes out for the auto guys, it will drop .5 from most of there ET's.I don't mind being compared to autos though Link to comment https://www.fordxr6turbo.com/forum/topic/28537-new-turbo-installed/page/2/#findComment-436381 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 6m 16d Gender: Male Location: Perth, WA Posted 16/09/06 10:40 AM Share Posted 16/09/06 10:40 AM Bearings failed in the old one, hence the buggered wheels..Yeah, huffer is a wog special.. ??←What happened to the bits that came off the compressor wheel Link to comment https://www.fordxr6turbo.com/forum/topic/28537-new-turbo-installed/page/2/#findComment-436552 Share on other sites More sharing options...
Guest newl Guests Posted 16/09/06 10:41 AM Share Posted 16/09/06 10:41 AM They've probably been swept up after leaving them on the track. Link to comment https://www.fordxr6turbo.com/forum/topic/28537-new-turbo-installed/page/2/#findComment-436553 Share on other sites More sharing options...
VLTurnaround Member 15 Member For: 19y 7m 16d Posted 16/09/06 11:08 AM Share Posted 16/09/06 11:08 AM why did the bearings fail?I was at the top of the thread wondering why you were getting a new turbo, scrolled down a bit, Ah ha, that'd be why. Link to comment https://www.fordxr6turbo.com/forum/topic/28537-new-turbo-installed/page/2/#findComment-436573 Share on other sites More sharing options...
