Edit Revs Drop And Then Comes Good When Stopping
Featured Replies
#1
Hi, has anybody had this problem with their car? I have the edit in it and all the latest up dates it is an auto 2004 BA. When you stop at the lights and sit for a few seconds still in drive the revs drops for a few seconds and them comes good again.
If you were to take off when the revs drops the car is all sluggish.
Thanks your advice would be helpful. I know that this is happening in another car and it is manual, with an edit as well with all the latest up date.
#2
I had a similiar problem with mine awhile back, the problem with mine was that the idials were dropping and climming and most times the car on idial in park use to stall.. its the edit go back to your tuner and he should fix it nizpro fixed mine within 20min.
#3
My ute did that.
Some idle rpm setting was set to 450 instead of 550.
All better now.
#4
  • Author
can I just send the box or did thay need the car to
#5
can you post all the symptoms please!!
ill see if I can help!!!!
#6
My ute did that.
All better now.
you speak of min idle allowed this is set to 550-600 as std on my tunes
there is also some thing that is called a dash pot but from previous conversations with mike this does not seem to be it!!!
more info please as requested b4
#7
  • Author
You stop at the lights and I do not give my car a hard time sit revs drop below 1000 rpm back to 450 rpms and then picks up it can be cold or hot day some times it does it some day it is ok you give it a good run you park your car in the garage place in park and dose it agene.
#8
I have had this before... pull up at the lights, come to a stop and all of a sudden the revs drop and the car almost stalls....... I dont have it with my current tune but I do know what you are talking about :dontknow:
#9
I had an intermittant problem like that a fair while ago. Ford said it was either a dirty throttlebody or something to do with the cam phasers? Anyway they fixed it and it was fine.
If the problem was in the edit would it not be consistantly there all of the time when at idle?
#10
Well mine is teh 04 xr6t manual that does it too. Ay one stage it was reving by itself aswell as this rev dropping problem aswell. I cleaned the throttle body as it was full of thick gunk and it fixed the problem for 2 weeks then it started again. I took it to ford and they replaced the TPS. It got rid of the revving by itself and stalling problem but it still occasionally does the rev dropping to bout 250rpm. I have tried both the standard and the 8psi tunes and it does it with both.
Hopefully when I get a custom tune shortly it will fix the problem.
Nesh
Recently Browsing 0
