So I Can Select Reverse From 4th
Featured Replies
#1
I'm not sure if this is 'normal' or not, certainly haven't come across it before and was wondering if I should let the dealer have a look?
I have a Mk2 T with the 6sp manual. I'm fairly sure I wasn't able to get the gearstick through the gateway to 6th once the car was going forward but the other day I nearly went to Reverse from 4th by accident. The gearbox made a crunching noise to tell me I made a mistake but I thought I wasn't able to get that far in the first place.
Can anyone please let me know if that is indeed a fault I shuld have fixed?
Cheers :spoton:
#2
that's the syncro's doing there job stopping you.
#3
  • Author
Thanks Slymeat, I thought as much, but should I be able to get to that point in the first place?
#4
i'd say no on that one..sounds like you reverse lock out solenoid isnt doing its job.
#5
I had that happen, but I only noticed it with the generic capa map in it and wondered if the genric didn't have the ability to activate the solenoid
#6
I had it happen at 160kph. Nasty. Reverse solanoid lockout not working. Off to the dealer with it..
  • 3 weeks later...
#7
Sounds like the reverse lockout is being powered up when it should not be. Many cars with a/m tuning have this problem. I have only ever seen one solenoid fail, and they fail safe, not open. Mal.
Recently Browsing 0
