Electrics Problem
Featured Replies
#1
hey guys, ive just installed miss alys gauge pod and two cobalt gauges, and it looks great. but I realised during the process something happened to the lcd screen and all the electrics assoiciated with it. such as the fan radio,and ac.
I believe it might be a plug but I didnt pull out the icc, all I did was pull out the top clips and the top screw. has any one had this problem?
can anyone help me? thanks in advance.
#2
make sure the plug's clips are fulley out when you refit the icc. if they are not in the correct position, the icc plug wont snap fully into place & pins can be bent or damaged
#3
He didnt pull out the IC, just came in through the top.
Scotty
#4
Have you checked the fuses..? where did you get you power supply from?
#5
sounds like a fuse to me too
#6
  • Author
I got the power and illumination from the fake traction control button.
I got all the fuses checked under the hood and also near the driver side kick panel, and they were all fine
#7
sorry, I miss read that. If not a fuse, try checking the relays have not been dislodged. easist way to fix I would guess is trace the fan circuits back. have a close look at where u ran the wires, in case u knocked a plug or something off
Recently Browsing 0
