  • Legacy Donating Member
  • Member For: 22y 5m 15d
Posted
I believe retail, it's somewhere just south of $3k. Controller is extra, doesn't come included in the kit.
Tein_Ford_Kit___List_Price.pdf
Not the most helpful .pdf, but gives you a look at the setup at least.
  • Replies 38
Posted
Certainly not cheap, how does it compare to other brands on the market. I found the controller on ebay for $359 us new, so add $5oo or so ontop.
  • 2 weeks later...
  • Formerly Turbo6
  • Member For: 23y 8m 26d
Posted
I called Fulcrum....
$2650 for all four corners for the Tein gear and the controller was $560 I believe so not too bad IMO.
The ride height is all preset so you can tailor from a good starting position.
Posted
WHat so we can't adjust the height at all.
  • Formerly Turbo6
Posted
I said the height is preset so "WE can tailor" from a good starting position.
Posted
How much height adjustment does it have, I thought you ment they set the height to where you want then that's it.
  • Formerly Turbo6
Posted
Have a look at the picture in the pdf - plenty enough I say.
  • Member For: 20y 8m 25d
Posted
I think there is well over 40mm of adjustment. They set the height when they install and tune the suspension and based on what you want, but say you are going out to the track you might to lower it 20mm and you can do so reasonably easily and set it back at end of day.
Of course the ultimate would be to be able to change ride height from inside car with the touch of a button, but then you a looking a whole lot of dollars. Only a few Euros I seen have this. But the extra controller allows you to change damper rates from inside car, which is a nice feature.
