Injectors Installation
Featured Replies
#11
How hard is it to take the throttle body off without damaging the gasket? Or would it be better to have a spare gasket on hand just in case?
#12
You can't damage the Throttle Body gasket..
#13
Thanks. Sounds like the trickiest bit is not loosing the spring clips. I'm going to tackle this job real soon, for the first time as you can probably tell.
Cheers
#14
Make sure you use a decent amount of lubricant on the injector "o" rings (vaseline works a treat)....dont try and fit them dry as you will most likely split the "o" rings which will spell trouble when you start it up the first time  :censored:
Without sounding like a sicko perv, ky works better
#15
I beg to differ....
Be careful.
#16
So I just take out the stock ones and the 968's will be straight fit replacement?
Nesh
Yes Nesh the 968 are a direct replacement and fit straight in. All up the job should take you approx 30-60 mins
:crybaby:
Really? Won't he require a custom tune after the larger injectors go in? I would have thought it'd run way too rich otherwise? :spoton:
Recently Browsing 0
