  • Member For: 19y 8m 21d
what did your tuner tell you.. or you havent spoke to him yet.. it could be like what cobrav8 has said that the tuner could have backed off..
Dont know if he backed off or not
  • Replies 23
Posted Images
if the tuner was backing off wldnt the boost drop off as well.do you have standard valve springs??
I have got the springs done.I would have thought the boost would drop off
  • Member of team Kittens
  • Member For: 21y 4m 19d
Are you sure that isnt the tester backing off at that point?
I doubt this very much - torque is falling away at that point, and if it does so quickly enough, then power will drop.
Curve looks fine to me - but expectations will depend on what other mods you have!
Maintaining high torque at high rpm is very hard particularly with the stock induction plumbing, and to a lesser extent the stock exhaust (well cat anyway), as losses are much higher with the higher flow rates.
Based on the amount of boost, I would hope valve springs have been done.
If you post up the rest of your mods, I am sure we can provide some more constructive comment. :spoton:
Cheers,
Ben.
Is the torque on the dyno sheets also accurate?  :spoton:
Yep - this is at the wheels - so you would need to divide by the diff ratio assuming the gear used was 1:1 for "engine torque at the wheels"
Cheers,
Ben.
Hi Ben, the mods are
42 injectors
Hyperflow IC
Flasher
K&N
CAI
Valve Springs
Cat gone and centre muffler gone
320rw backed off to 303rw
Thanks Bill
