25/05/06 08:39 AM25/05/06 08:39 AM #11 Hrmm...What springs did you have Adrian? Are the Pedders that different to the Kings?? Or are one set of springs different to another regardless of manufacturer?←Ive got LovellsI still dont believe that that is the problem because I have seen so many BAs on there a$$. I refuse to swap mine out.←My suggestion is get the springs swapped for another pair of lovells... might help your cause. I wouldnt rule it out mate, every car will react differently to adjustments and modifications.←Anyone want to swap springs for a day? Preferably Kings and only the rears.
25/05/06 08:40 AM25/05/06 08:40 AM #12 Ok, your problem is diffrent to mine. Mine has the same characteristics in 2nd 3rd 4th 5th 6th (won't do 80 in 1st!!!!!!). I have a small amount of vibration and some harmonics. Simon suggested tyres and I believe this maybe the cause. If it isn't then I'll punish the &^%$ out of it.
25/05/06 08:41 AM25/05/06 08:41 AM #13 Ok, your problem is diffrent to mine. Mine has the same characteristics in 2nd 3rd 4th 5th 6th (won't do 80 in 1st!!!!!!). I have a small amount of vibration and some harmonics. Simon suggested tyres and I believe this maybe the cause. If it isn't then I'll punish the &^%$ out of it.←Your car or Simon
25/05/06 08:42 AM25/05/06 08:42 AM #15 Hrmm...What springs did you have Adrian? Are the Pedders that different to the Kings?? Or are one set of springs different to another regardless of manufacturer?←Ive got LovellsI still dont believe that that is the problem because I have seen so many BAs on there a$$. I refuse to swap mine out.←My suggestion is get the springs swapped for another pair of lovells... might help your cause. I wouldnt rule it out mate, every car will react differently to adjustments and modifications.←Anyone want to swap springs for a day? Preferably Kings and only the rears. ←Warranty? Where/when did u buy them?
25/05/06 08:45 AM25/05/06 08:45 AM #16 Warranty? Where/when did u buy them?←Well what I want to do is see if it is the problem. It takes bugger all time to change out the rears especially lowered rears.I got them from WA suspensions.
25/05/06 08:47 AM25/05/06 08:47 AM #17 Ok, your problem is diffrent to mine. Mine has the same characteristics in 2nd 3rd 4th 5th 6th (won't do 80 in 1st!!!!!!). I have a small amount of vibration and some harmonics. Simon suggested tyres and I believe this maybe the cause. If it isn't then I'll punish the &^%$ out of it.←Your car or Simon ←Nah my 0.3 frame won't be punishing simon anytime soon!
25/05/06 08:48 AM25/05/06 08:48 AM #18 Ok, your problem is diffrent to mine. Mine has the same characteristics in 2nd 3rd 4th 5th 6th (won't do 80 in 1st!!!!!!). I have a small amount of vibration and some harmonics. Simon suggested tyres and I believe this maybe the cause. If it isn't then I'll punish the &^%$ out of it.←Your car or Simon ←Nah my 0.3 frame won't be punishing simon anytime soon!←
25/05/06 08:50 AM25/05/06 08:50 AM #19 Sounds more like a wheel weight... get em balanced←Yeah cheers, I suspected that but all the weights are still there. I'll take your advice and do it anyway cos your probably right!!!!! I HOPE.
25/05/06 10:33 AM25/05/06 10:33 AM #20 Author Have you got this vibration issue adrian? I have a vibration issue that began after I took my T 4WD'ing. I swapped tyres front to back and the problem is still there but slightly less. Still only at 80km/hr. I had a major underneath the car but found nothing. I did notice that the rear (drivers side) tyre....now front....had a very slight wobble in it......the rim appears perfect but I'm suss on this tyre, could be my problem.Good to hear hippo and glad it's fixed. It's a good feeling when a constant problem is repaired for good. I had a 2000 Jackaroo that would always overheat on long trips. Anyway after taking it to Expensive Daewoo several times they could never find the issue. I then took it to ford (old man worked there) and by the time I had left the building they had found the problem....steel radiator instead of alloy. the rad looked like a ballon on the outer edges.........CLASSIC.←Yeah I have the same as Hip. Ive had it for about 8 months now. It only happens when accelerating in 3rd and above. When im cruizing its not there. Its a real piss off.I dont think you could call his car fixed (as in Ford putting stock springs back in) as ive seen so many BAs on there a$$.It feels as if the only time it happens is when the driveline is under its torque.CheersAdrian←Ahhhhhhhhhhhhhh. that's the problem Adrian, apparently (according to Titans) some cars do it while others don't, bloody weird if you ask me . Anyway, you should feel it up around the 250 mark
