coach3062 Member 91 Member For: 20y 7m 22d Gender: Male Location: North west NSW Posted 24/05/06 01:33 PM Posted 24/05/06 01:33 PM I need input from the many wise heads that populate this forum.How much does the position of the boost gauge hookup relate to the pressure reading on a boost gauge?My Speco boost gauge reads 8lbs on standard, 12psi on the generic 8lbs program and 15lbs on the generic 10lbs one.Does this mean that that by the time the boosted air reaches the throttle body that friction losses, restrictions and obstructions in the flow path (ie: intercooler etc) cause the pressure to drop? Or do I have a crappy gauge that needs to be calibrated or should I send my gauge to turbo heaven? I currently have my gauge run off a t-piece straight from a pickup on the snail. Is this where most are connected, or if not, where should it be plumbed?
exahsix Member 296 Member For: 20y 11m 29d Location: Monterey, NSW Posted 24/05/06 02:16 PM Posted 24/05/06 02:16 PM Without knowing the exact fittings on the engine I would say the best place to fit the hookup is as close to the inlet valves as possible. Thoeretically this gives the most "true" boost reading of what's going in the engine. So a t piece or fitting on the inlet manifold would be best.That way all the pressure losses of the piping and interooler are accounted for.
Mac Daddy Member 103 Member For: 21y 2m 4d Location: brisvegas Posted 24/05/06 02:20 PM Posted 24/05/06 02:20 PM most members have opted to fit the t piece on the pipe connecting the bov behind the crossover manifold including m and it is always fairly accurate give or take .5 psi
LightningXR6T Member 197 Member For: 21y 2m 27d Location: Newcastle NSW Posted 26/05/06 10:07 AM Posted 26/05/06 10:07 AM most members have opted to fit the t piece on the pipe connecting the bov behind the crossover manifold including m and it is always fairly accurate give or take .5 psi←I have connected my boost gauge in this position. Std tune registers 6psi, 8psi tune registers 11psi and the 10psi registers 15psi. Have had the T checked by Ford, had tunes updated by supplier, no one seems to be able to answer why. I have verified that the gauge is reading correct by having it checked by a company that calibrates gauges for mining and medical industries. This company is also the only registered business here that can work on police vehicle gauges!
Adam Here since the start... Legacy Donating Member 10,282 Member For: 23y 5m 2d Gender: Male Location: Victoria Posted 26/05/06 10:16 AM Posted 26/05/06 10:16 AM I currently have my gauge run off a t-piece straight from a pickup on the snail. Is this where most are connected, or if not, where should it be plumbed?←That explains why your gauge is showing more pressure.Because of the pressure drop that occurs across the intake and intercooler the turbo has to produce more boost to overcome this. So getting 8PSI to the throttle body might actually take 12PSI from the turbo.
FPV TRANNY Im the one and only Legacy Donating Member 3,557 Member For: 21y 8m 21d Gender: Male Location: In my house Posted 26/05/06 10:23 AM Posted 26/05/06 10:23 AM most members have opted to fit the t piece on the pipe connecting the bov behind the crossover manifold including m and it is always fairly accurate give or take .5 psi←I have connected my boost gauge in this position. Std tune registers 6psi, 8psi tune registers 11psi and the 10psi registers 15psi. Have had the T checked by Ford, had tunes updated by supplier, no one seems to be able to answer why. I have verified that the gauge is reading correct by having it checked by a company that calibrates gauges for mining and medical industries. This company is also the only registered business here that can work on police vehicle gauges!←If your gauge is true I would believe that 15psi on std injectors would mean KABOOM
LightningXR6T Member 197 Member For: 21y 2m 27d Location: Newcastle NSW Posted 26/05/06 09:05 PM Posted 26/05/06 09:05 PM most members have opted to fit the t piece on the pipe connecting the bov behind the crossover manifold including m and it is always fairly accurate give or take .5 psi←I have connected my boost gauge in this position. Std tune registers 6psi, 8psi tune registers 11psi and the 10psi registers 15psi. Have had the T checked by Ford, had tunes updated by supplier, no one seems to be able to answer why. I have verified that the gauge is reading correct by having it checked by a company that calibrates gauges for mining and medical industries. This company is also the only registered business here that can work on police vehicle gauges!←If your gauge is true I would believe that 15psi on std injectors would mean KABOOM←That is why I removed that tune immediately. I currently run the 8psi (11psi) tune and a friend of mine who has had his T custom tuned by Intune @ 256rwkw's, says my T feels stronger.I know if I took it to CAPA they would sought it out in a heartbeat. But here in Newcastle there's no one who can help!
Street Tuner Member 727 Member For: 23y 9m 4d Posted 26/05/06 09:17 PM Posted 26/05/06 09:17 PM Connecting the boost gauge up properly - ie to the manifold would be a good place to start
BFHOON Legacy Donating Member 1,932 Member For: 20y 6m 4d Gender: Male Location: nsw Posted 26/05/06 10:47 PM Posted 26/05/06 10:47 PM anywhere after the throtle body butterfly
