  • Member For: 20y 6m 15d
Posted
G'day all.
I am looking at purchasing a CAPA flash tuner as from what I have read here they seem to be the best bang for the $ My question is, at what power figure {RWKW} would it be advisable to upgrade the valve springs and what exactly are the benefits of doing so? I have read so many different views in regards to this that for a novice like me it can get quite confusing. Also generally, what cost factor would I be looking at for springs and installation?
Much appreciated,
Michael
PS: Autobrakes Winton Track Fun Day 16-7-06 $25 :pinch:
  • Seriously Flukey Member
  • Legacy Donating Member
  • Member For: 22y 6m 20d
Posted
G'day all.
Much appreciated,
Michael
What model T do you have?
  • Playing with Sports Bikes...
  • Member For: 20y 11m 12d
Posted
Hey Michael,
if you are just looking at doing an edit tune only on the car then the factory valve springs and injectors will handle that quite easily... any further than that and you will hear differing opinions of what is best... I personally would recommend taking to one of the well known tuners down in Melbourne (I see your from Shep) and go from there...
Currently I have just an edit tune on an early series 1 BA, and my next mod in the next couple of weeks will be injectors and valve springs, that is what my tuner (Nizpro) has recommended to me and that is what I am going with...
Jack :pinch:
Posted
An edit and custom tune would take you to about the valve springs limit, ~250rwkw's.
The series 1 valve springs wont handle much more power and the car will suffer from valves bounce :pinch: if you push the car much past that.
Do edit 1st and see what you think.
Posted
Thanx heaps, much appreciated. It awesome having such help an information available here at my fingertips.
Cheers :pinch:
  • Member For: 21y 1m 24d
Posted
My valve springs were ok up to about 270rwkw on a soft tune although I have a 2004 late year model and I think the springs may have been different than yours. I also had a full exhaust and that helps relieve the pressure on the springs.
When I added an intercooler and better tune (C&V :laughing: ) they started acting up big time.
  • Member For: 20y 11m 21d
Posted
I got my 05 MK11 up to 320rw on the dyno and my springs let go so they had to be replaced.I had 285rw before that with no problems.
  • Crusty aviator
  • Member For: 22y 3m 22d
Posted
It's more a function of boost pressure and revs rather than power. I could run 280RWKW with APS Phase II but with the Edit raising the boost to 12.5 rather than the 10psi used with the APS Phase II, above 5000 RPM one or two of the springs found it hard to cope. Thus I'd advise going ahead with the tuning and see if and when the springs become an issue and then make your decision whether to press on and get the springs changed or keep the pressures/power below the precipitating figures. That said FOR MY T (BA MK 1) at or above 5000RPM on the 309RWKW tune, changing my springs made a 70RWKW difference.
Dingah
  • Wanabe mechanical engineer
  • Member For: 22y 25d
Posted
If the funds are available just get it all done at the same time.... Have 1 tune for all out power and then a 2nd tune to run on 95RON fuel @ about 250rwkw....
That way there is no fuss about it.......
