PSYCHO XRT THE PSYCHO XRT Legacy Donating Member 1,275 Member For: 20y 9m 22d Gender: Not Telling Location: At the lights! Posted 07/04/06 05:20 AM Posted 07/04/06 05:20 AM (edited) Dont expect your T to go Boom if you use the std deck!!! Must use aftermarket deck of some kind!!! Cheers & its a good idea you have done.←Dont need an aftermarket deck to get great sounds.Come and here my Factory deck which is running off a 2x12inch subs, and then let me know if u can here the boom or not!! Edited 07/04/06 05:22 AM by citricxr6t
joostenjohn60 Member 16 Member For: 20y 7m 10d Posted 07/04/06 05:27 AM Posted 07/04/06 05:27 AM That looks good . I am going to upgrade the subs in my T soon but I tend to prefer infinate baffle loading , firing the sub through the fold down seats and using the boot as your box. this type of loading with a good speaker will give much better sound quality so long as the volume of the boot is more than 4 times the VAS of the driver and there is a reasonably good seal between the boot and cabin. In my home theatre I have 4 15" drivers mounted in the roof firing through air con grills into room, sounds awesome.
Goobz Member 746 Member For: 21y 11m 18d Location: Sutherland Shire, Sydney Posted 07/04/06 12:42 PM Posted 07/04/06 12:42 PM FYI the sub box is about 48l, it has 2 50mm ports which are 78mm long it is tuned to 32Hz and the port have a coefficient less than 0.15 so they don’t whistle. The port size and length will be different for every woofer.←Ok then. Well that just went straight over my head!!! Does anyone want to explain how I could build something like this myself without having to measure all that or is there somewhere I can get a program to work it out? I am good with the tools. Just not with the coefficient of ported hertz tuning! Does the sub you buy tell you what you need or do you need to work it out?Chris
shockF6 Legacy Donating Member 478 Member For: 20y 11m 26d Location: Melbourne Posted 07/04/06 12:57 PM Posted 07/04/06 12:57 PM Does anyone want to explain how I could build something like this myself without having to measure all that or is there somewhere I can get a program to work it out? I am good with the tools. Just not with the coefficient of ported hertz tuning! Does the sub you buy tell you what you need or do you need to work it out?←a program called bass box pro is what you need when you buy the woofer it will (should) come with a data sheet. punch the numbers into bass box pro and it will spit out all the data you need to build a perfect box for your subby. You can also change the shape of the box and bass box pro will adapt port size and length to suit.
Goobz Member 746 Member For: 21y 11m 18d Location: Sutherland Shire, Sydney Posted 08/04/06 02:11 AM Posted 08/04/06 02:11 AM Sweet! Thanks again mate! How are those audio boxes coming along?Chris
joostenjohn60 Member 16 Member For: 20y 7m 10d Posted 08/04/06 08:38 AM Posted 08/04/06 08:38 AM Just tell me what sub you are going to use and I will do the calculations for u. you can then work out the shape all you have to do is keep the volume the same . also state whether you want sound quality or just plain decibels as it requires different type of box. john
Goobz Member 746 Member For: 21y 11m 18d Location: Sutherland Shire, Sydney Posted 08/04/06 01:30 PM Posted 08/04/06 01:30 PM Thanks for the offer mate! I won't be doing anything for a few months yet. I just like to prepare(gives me something to do!) early.If the offer is still open then I might take you up on it then! Chris
joostenjohn60 Member 16 Member For: 20y 7m 10d Posted 08/04/06 10:52 PM Posted 08/04/06 10:52 PM The offer will always be open . I have worked most of my life as a live sound tech/ engineer and I love playing with it so feel free whenever.
Goobz Member 746 Member For: 21y 11m 18d Location: Sutherland Shire, Sydney Posted 09/04/06 12:58 AM Posted 09/04/06 12:58 AM Sweet! Thanks mate. I'll drop you a PM when I'm ready!Chris
81CJH Member 204 Member For: 21y 13d Gender: Male Location: Brisvegas Posted 10/04/06 11:58 AM Posted 10/04/06 11:58 AM In my home theatre I have 4 15" drivers mounted in the roof firing through air con grills into room, sounds awesome.← Diggidy DAMN!I like the way you think.
