  • Site protagonist
  • Legacy Donating Member
  • Member For: 23y 4m 28d
Posted
I picked up 50rwhp with an SMB dump pipe and cat. A good hiflow cat should get you the numbers your looking for with an edit to match the better flow.
<{POST_SNAPBACK}>
I've got edit, injectors and valve springs done for 257rwkw's @9psi - I cant get any more out of it.
I definately have restriction in the exhaust but dont want to spend $2K on a Difillipo or APS replacement.
I am hoping a hi-flo ( or gutted cat ) will get me closer to the 290kw's and perhaps an 11 :laughing:
<{POST_SNAPBACK}>
Luke it's possible that your current cat is collapsing and causing even more restriction. There is a way to check this but I don't recall what it is.
Geea. :laughing:
  • Replies 54
Posted Images
  • TRAITOR
  • Member For: 23y 11m 21d
Posted
Geea. :laughing:
With a torch, have a look up your exhaust. Any gold flakes in there reflecting the light? Sure sign of collapsed cat.
  • Here since the start...
  • Member For: 23y 5m 14d
Posted
Hey Flukey...
I believe AdamXR6T has an SMB dump and cat while retaining a factory exhaust and intercooler and he is making in the region of 285rwkw...
Is that the kind of no. you are looking for?
Hope this helps...
Jack  :k24t:
Yeah Jack,
I think you are right about Adam's T. that's closer to what I want to get to.
Luke here's a pic of my dyno chart with before and after SMB dump pipe and cat installation. I made more power everywhere with good gains in the upper rev range, also peak power is developed a bit earlier aswell with no more boost than I already had.
Cheers,
Adam. :hrmm:
  • Member For: 21y 7m 16d
Posted
Hey Flukey...
Hope this helps...
Jack  :k24t:
Yeah Jack,
Cheers,
Adam. :hrmm:
<{POST_SNAPBACK}>
Adam
did you need to get a retune after you got it fitted ? or was it safe to run as is after the installation ?
Posted
Not sure whether it would have been safe or not.
It was retuned straight after installation.
A retune would be required to get the most from it.
  • Team Xtreme
  • Member For: 21y 8m 2d
Posted
I got to 380 rwkw with stock zorst and smb dump and cat.
  • Forum Superhero
  • Member For: 22y 10m 13d
Posted
Luke, my old car was running 281rwkw's with centre muffler removed and gutted cat. With these mods I was still able to run standard valve springs as the backpresure wasn't an issue. My car was running 12.2@116 with Xede well before the edit came along. I'd think it would have gone alot quicker with the same mods with edit.
Geea. :k24t:
I remember. Does that exhaust stink with a gutted Cat?
Hey Luke, no it does not smell, I had 294rwkw with the complete standard exhaust except I had Geeas gutted standard Cat.
I would suggest it was close it it's limit as sometimes under full throttle or backing off you could hear it struggling under pressure and sometimes would hesitate until it had cleared itself.
Cheers
JB :hrmm:
JB, did you have standard valve springs at the time?
Hey Rob, no mate the valve springs got changed at 260rwkw which then took me up to 274rwkw.
  • Forum Superhero
Posted
Out of interest are the typhoon exhausts same as the T's? Down the track I maylook at one but would want to put on a aps zorst
  • Seriously Flukey Member
  • Member For: 22y 6m 19d
Posted
Hey Flukey...
Hope this helps...
Jack  :k24t:
Yeah Jack,
Cheers,
Adam. :hrmm:
Thanks Adam. That looks like my next mod.
Posted
I never thought it could take that much power
