LTSBGY Member 259 Member For: 20y 8m 24d Posted 19/01/06 10:27 AM Posted 19/01/06 10:27 AM Has anyone got 18's or 19's and lowered the car ridiculously? Is ther much camber and if so has anyone put in a camber kit? Did the camber kit do much?Nesh
JB Forum Superhero Legacy Donating Member 3,109 Member For: 22y 10m 14d Location: Eastern Suburbs of Mexico Posted 19/01/06 10:33 AM Posted 19/01/06 10:33 AM Has anyone got 18's or 19's and lowered the car ridiculously? Is ther much camber and if so has anyone put in a camber kit? Did the camber kit do much?NeshNo Nesh, I had 19's with King Springs on it SSL rears and SL front to level it out. Only had a wheel balance when I put the springs in, never needed touching it after that. Also had an APS exhaust which made it lower again as that became the lowest point on the car. Took speedhumps carefully, besides that no probs.CheersJB
Trough Lolly Member 4,349 Member For: 22y 1m 2d Gender: Male Location: Mildura Posted 19/01/06 10:38 AM Posted 19/01/06 10:38 AM ive just purchased a kmac camber/castor kit. the insides of my fronts have wire hanging out and the tires still got 60% tread. this is after 2 so called "wheel alignments" carried out by the ford monkeys.
LTSBGY Member 259 Member For: 20y 8m 24d Posted 19/01/06 10:40 AM Author Posted 19/01/06 10:40 AM The front height is perfect but im looking to slam her in the ass end as low as I can go. The closer to the rim the better. Im thinking about just getting the springs compressed or buying king springs and getting them compressed. Im jus worried bout camber coz tyres are expensive when there is camber. Like the holdens when you slam them and put a camber kit in it does bugger and I dont want to spend money on a camber kit if its not gona do anything
bob^ Member 170 Member For: 22y 11m 7d Location: Geelong Posted 19/01/06 11:52 PM Posted 19/01/06 11:52 PM Nah they're nothing like a Late model camira rear end. The rear doesn't have to be touched. Only the front in some cases.
Benny Member 1,869 Member For: 23y 2m 5d Gender: Male Location: Newcastle Posted 20/01/06 01:31 AM Posted 20/01/06 01:31 AM The front height is perfect but im looking to slam her in the ass end as low as I can go. The closer to the rim the better. Im thinking about just getting the springs compressed or buying king springs and getting them compressed. Im jus worried bout camber coz tyres are expensive when there is camber. Like the holdens when you slam them and put a camber kit in it does bugger and I dont want to spend money on a camber kit if its not gona do anything<{POST_SNAPBACK}>The camber can be adjusted on the rear of the XR when a wheel alignment is done. I think the major factor that you need to consider when lowering the rear alot is the small bump stops that are located on the suspension arms. How much will need to be cut off them and what clearances/travel you'll have after it's done. With the SSL's the bump stops have to be trimed but with compressing them again they might have to be removed all together.
igsta Member 371 Member For: 23y 1d Gender: Male Location: Sydney Posted 20/01/06 05:32 AM Posted 20/01/06 05:32 AM If you lower the front with SL you should be fine. I have SSL in the front and my camber is almost negative 1.5 degrees. My insides wear out alot quicker than the rest but having 19's and my driving style dosnt help. The camber kit will fix it though if set up right.
Trough Lolly Member 4,349 Member For: 22y 1m 2d Gender: Male Location: Mildura Posted 20/01/06 06:00 AM Posted 20/01/06 06:00 AM If you lower the front with SL you should be fine. I have SSL in the front and my camber is almost negative 1.5 degrees. My insides wear out alot quicker than the rest but having 19's and my driving style dosnt help. The camber kit will fix it though if set up right.<{POST_SNAPBACK}>indeed, that's the problem I have. getting the kit put in next week as I killed a set of fronts in 6000km's on the insides they are thru to the wire
LTSBGY Member 259 Member For: 20y 8m 24d Posted 20/01/06 11:31 AM Author Posted 20/01/06 11:31 AM So its the front that camber on the BA's not the back? So you need a camber kit for the front? Trough Lolly when you get the kit put in can you tell me if it makes it perfectly straight or near perfect. ThanxNesh
Guest newl Guests Posted 21/01/06 08:54 AM Posted 21/01/06 08:54 AM So its the front that camber on the BA's not the back? So you need a camber kit for the front? <{POST_SNAPBACK}>That depends on who you talk with. Cro for example will tell you to make sure your tire pressure is correct first, then a camber kit if still needed.
