  • Member For: 22y 1m 30d
Posted
Does the DVD still play while driving ?
No. For saftey reasons our system will only display the DVD picture once the handbrake is engaged although sound can still be heard in any condition with our manual switching system.
Do they bend the rules so u can watch anytime??
  • Replies 52
  • Here since the start...
  • Legacy Donating Member
  • Member For: 23y 5m 3d
Posted
Apparently not.
Posted
Pretty much pointless then hey! Not so much for me to be watching and driving the passengers!
  • Member For: 23y 7m 30d
Posted
It is against the law for them to install it so it will work while driving. It is a 5 minute job to bypass the handbrake switch though once you get the car home. Just remember though if the police see the screen while you are driving there is no comeback and I believe it is a 3 demerit point offence.
  • Member For: 20y 11m 24d
Posted
I have an xbox modded and a 160gig HD and much would someone charge just to install in my car??
what state are you in, I may be able to help.
Posted
<{POST_SNAPBACK}>
Cant u just swap it over with a switch to the normal screen?
  • Member For: 21y 11m 17d
Posted
In your opinion, which is the better way to go(Bios flash or mod chip), and if so which chip?
Also roughly what does this stuff cost to get done, and how do you find the guys that do it?
<{POST_SNAPBACK}>
Hi Chris,
I have never done the soft mod myself so I cant really comment on it other than to say that I went for the mod chip because you have more control and can change between bios's and dashboards whenever you have the need to.
Im sure there will be tonnes of topics on this if you shoot over to xbox-scene :stirthepot:
my mod chip cost me just over $100 inc shipping from the US because I went for the solderless option (at the time I was thinking of removing the mod chip once the xbox was set up for the car).
once again as I didnt get anyone to do the mod for me I cant comment on where or how much to get installed but I have been told by others that you can get a generic mod chip installed at computer swap meets for around $80.
As far as I can tell, the only diference in the mod chips is the easy of selecting what bios to load and the size of the onboard ram (or how many bios's can be stored on the chip)
Let us know how you go with your research :laughing:
<{POST_SNAPBACK}>
Which chip did you end up going for?
Are these 'solderless' versions hard to install? Do they include an external switch(is this really needed?) or is this something you have to do yourself?
Also with the HDD upgrade. Do you simply swap out the old one with a new one or setup a slave? Are they just a std PC HDD?
Sorry for all the questions. I'm a bit of a newbie at all this...
Thanks mate
Chris :censored:
Posted
Sorry, forgot to add - which dashbord are you using?
Thanks
Chris
Posted
the chip I used is a Xenium SP.ICE solderless chip. Including unscrewing the case it was installed and running in under 5 minutes :spoton:
it does come with an external switch but I havn't bothered connecting it because you do everything through software anyways.
the mod chip bios is what you use to setup a new xbox hdd. the instruction manual of the mod chip will show you how and yes they are a standard ATA style PC drive :msm:
The dashboard I run is XBMC because in the car the main thing I use the xbox for is MP3's and music videos.
p.s if you know how to use torrents, search for a torrent called "xbox maker 1.5". its the best thing you can download if your only just starting out with xbox
