  • Playing with Sports Bikes...
  • Legacy Donating Member
  • Member For: 20y 11m 9d
Posted
Hey guys...
As I have a T5 and don't wanna lunch my T5 by having a world of torque kill it, I was thinking of getting an edit done but having a more efficent intercooler fitted at the same time, rather than injectors and valve springs... as I think the intercooler will make the edit more repeatable performance wise...
Has anyone done this?
Because I figure I can do valve springs and injectors and transmission upgrade later on if I want to, but I think from reading all the posts about performance and stuff that the valve springs and injectors will take me too close to edge of killing my T5... whereas an edit and 'cooler will make my car repeatable perfomance wise and also more efficient to drive regardless of the weather be it hot or cold...
What do you guys think? Am I mad? Do I not know what I am on about? Or is this a plausable 1st modification?
Cheers
Jack :spoton:
  • Here since the start...
  • Member For: 23y 5m 12d
Posted
For a mild upgrade I think the combination you have mentioned would work just fine. The cooler would probably give you a few more kw's aswell as that repeatable performance your after.
  • Member For: 22y 8m 7d
Posted
with e T5 the mods you have mentioned are the best option IMO...you can safely pump out a repeatable 240-250 rwkw.... you dont want more then that with the T5 :spoton:
  • Member For: 21y 1m 28d
Posted
What your thinking is all about you can do with a T5.
I have A Good WOG Edit,IC and little more making over 300 and I am worried about the MarkII GearBox T56. It would Smash a T5.
GC
Posted
that gives you a nice amount of power,
with e T5 the mods you have mentioned are the best option IMO...you can safely pump out a repeatable 240-250 rwkw.... you dont want more then that with the T5 spoton.gif
And currently, considering I have to drive my car to work everyday and reliability is a huge concern... and though my no. plates might suggest I want to be BCL... I don't... I reckon you boys are right... repeatable performance is what I am after, not a dyno queen or track weapon yet... just something that when I wake up in the morning for work I can't wait to drive to...
Jack :spoton:
  • Member For: 23y 3m 11d
Posted
A very good first option.
I would suggest that you start with the cheapest and open up the air intake before the IC and edit.
Also, TELL YOUR TUNER that you are looking for longevity rather than max power and torque. That way you will be fine. :nono:
