Performance Packages
Featured Replies
#1
Lets face it if you want to realise the true potential of an edit, and who amongst us doesn't, your going to need some form of exhaust mod, bigger injectors, a bigger IC, gearbox mods and depending who you speak to, stiffer valve springs / wastegate actuator and fuel pump etc not to mention a series of visits to the dyno for retuning.
Now I can't be stuffed adding all that up in $$ terms but I'm sure there could be some worthwhile savings for the end user if it were all wrapped up in an attractive 300+rwkw package.
Afterall it worked for APS and I'm sure the first edit tuner to do it would benefit from the professionalism associated with a well thought out and marketed approach to modifying an aussie performance car icon. :rockon:
#2
nizpro kits all include the edit now im pretty sure....from a stage 1 to 4
#3
Yup, PSISIX is right, you can get a range of all inclusive Cobra kits from Nizpro. :rockon:
jordak, whilst I'd love to have free reign over my T and mod it as I wished, there are also some of us who have decided to forego the extra performance to be had from Edit by adding the extra goodies you mention to maintain warranties, etc. :gooff::rockon:
#4
  • Author
<{POST_SNAPBACK}>
Yeh I know and they want over $8,000 for a circa 300rwkw stage 2 package that doesn't include an exhaust.
Point being the same result is being safely achieved by others for half that.
#5
<{POST_SNAPBACK}>
It doesn't have an exhaust because their intake setup is extremely efficient.
All Nizpro kits are now ADR/EPA approved aswell.
You could always just buy an APS kit sell the unichip and then get it edited.
#6
Sounds like good plan Jordak,
surely one of the tuners could come up with a package of say, trans cooler, injectors, dump pipe with hi-flow cat, larger IC, edit & custom tune for around $4000. This combination should be good for around 300rwkw safely. Does this sound feasable or am I dreaming?
Cheers,
Steve
#7
I think your dreaming for $4k.
#8
:spoton: Me will do.Need to strengthen auto first. :msm:
#9
A little more than 300rwkw, the stage 2 (with edit) makes the power so easily but because of the stock rods, more like Simon is turning down the power to 330-340rwkw at around 13psi, with a stock exhaust. :spoton:
#10
How about this;
intercooler $1100.00 fitted
twin magic cats from standed dump merged to standed twin 2x 2.25 pipes$750.00
injectors $1100.00 fitted
edit $1000.00
custom tune$500.00
valve springs fitted$ 600.00
line preasure switch fitted$150.00
$5200.00
This should give safe 300rwkw's and with senible driving should last.
or;
intercooler$1100.00 fitted
twincats as above$750.00
injectors$1100.00 fitted
line preasure lifted$150.00
convertor 3000 stall $1150.00 fitted
trancooler fitted $200.00 fitted
exede $1200 fitted and tune(or edit or unichip)
fuel pump, $250.00 fitted
M/t radials $650.00 fitted
This is what I have got, and has done over 200 Quarter runs and 20000 k's set up like this, and will run 11 sec times with anyone driving. $6550.00
Recently Browsing 0
