  • Member For: 22y 3m 10d
Hey Did anyone had a same problem, I've got ba xr6 turbo aps phase 2 kit in it (274rkw) when I takin off , when it goes to 2nd to 3rd it flares. I took it to ford to get it fixed, they say its not the gearbox problem, they say from lang. if its lang does it cause 2nd to 3rd flares,
regards
andrew
https://www.fordxr6turbo.com/forum/topic/18964-auto-problem/
  • Team Bute
  • Member For: 21y 11m 4d
Gearbox needs to be upgraded with PH2 power level (imho)
You're finding out the hard way.
Even if Ford fix the problem you have now, it will NOT last with the torque increase you get when increasing boost (with Ph2 and above)....
Increasing the ability for the oil to get away from the clutch surfaces and increasing the line pressure is paramount.
At the very least, the clutch plates on the 2-3 (and 3-4) shift need to be upgraded to the serrated style as used on the 1-2 shift.
Whilst its apart, Kevlar bands to replace the originals is a good idea.
There is also a need to increase the pressure so that bands and clutch packs are forced onto their respective components harder, to minimise potential to slip. There's a few other tricks that a good tranny tech can do, re blueprint all clearances of clutch packs, oil pump and end floats of all moving components.
Oh, and if you haven't got an additional tranny cooler, it should have been done before you installed Ph2! Get one, and make sure its located where it gets good clean cool air flow.
I mounted a Maxiflow cooler across the front of the radiator in the top grille opening. I also installed a 2800 high stall converter, but to be honest, the stock converter gets off the line and boogies better for everyday driving. My converter needs to be brake stalled to be effective. Good at the track, but just feels sluggish under WOT standing starts without brake stalling.
To give you an idea of costs..... And it will vary on what you have done, but I spent $2400 for all my mods... trans, cooler and converter.
cheers
tom
https://www.fordxr6turbo.com/forum/topic/18964-auto-problem/#findComment-275117
  • Member For: 21y 23d
Sounds like she's on the way out mate. Been there and done that 3 times and all replaced under warranty. :crybaby:
take turbotom's advise and get it upgraded.
If your in Melbourne Preston Auto's do all of the above for about $1000 or less depending on what your power level is and what you want done.
As far as I have heard. Everyone that has hed them done there are very happy customers. :spit:
macka
https://www.fordxr6turbo.com/forum/topic/18964-auto-problem/#findComment-275156
  • FORD FORD FORD
  • Member For: 22y 3m 2d
As the crowd say, she's gonna blow captn, get her dealt with before you have to push her
https://www.fordxr6turbo.com/forum/topic/18964-auto-problem/#findComment-275162
  • Member For: 20y 10m 26d
Had mine done at preston auto's, Very happy with it $725. The guys there are so helpfull and show you what's been done and why. Blown BA, Mr Turbo and others have been done there too. :spoton:
https://www.fordxr6turbo.com/forum/topic/18964-auto-problem/#findComment-275205
