Fozzie Member 71 Member For: 21y 7m 9d Gender: Male Location: Canberra Posted 24/05/05 11:10 AM Posted 24/05/05 11:10 AM hi ppl,just had my T in for a wheel alignment the guy said that my camber/caster was quite bad.I havent run up any gutters or anything either..here is what I got on the stat sheetCamber LT: -0.35Camber RT: -0.23Caster: LT: 7.82Caster: RT 7.40he also said that it looks like a manufacturer fault, anyone else had this problem? booked in to ford next week to see if there is any problem there...
AWW XR6T UTE Member 129 Member For: 23y 4m 12d Location: Brisbane Posted 24/05/05 11:26 AM Posted 24/05/05 11:26 AM Mine was the same, they had to use shims to get the alignment right. Might be common from the factory?
Paradoxx Colossal Member Member 5,049 Member For: 22y 25d Gender: Male Location: Perth, WA Posted 24/05/05 02:31 PM Posted 24/05/05 02:31 PM I have asked my dealer about this... http://www.fordxr6turbo.com/forum/index.php?showtopic=17528Steve.
Turbo6man Legacy Donating Member 4,084 Member For: 23y 11m 8d Gender: Male Location: South Coast NSW Posted 25/05/05 01:21 AM Posted 25/05/05 01:21 AM Those figures are within spec just with a quick glance at them. I'm assuming these are what they've set it at now? The car should drive fine. It's a pity they couldn't get the RH camber down to zero but hey, it's pretty close.
cobrav8 Member 1,969 Member For: 21y 5m 26d Gender: Male Location: New Zealand Posted 25/05/05 04:58 AM Posted 25/05/05 04:58 AM A little bit of negative camber is absoulutely fine. What is the issue?
Fozzie Member 71 Member For: 21y 7m 9d Gender: Male Location: Canberra Posted 26/05/05 12:36 AM Author Posted 26/05/05 12:36 AM I think he was more concerned about the high caster readingsit is driving fine now though, so im happy!
Turbo6man Legacy Donating Member 4,084 Member For: 23y 11m 8d Gender: Male Location: South Coast NSW Posted 26/05/05 01:41 AM Posted 26/05/05 01:41 AM I don't think those castor readings are excessive. What does you handbook say they should be? Maybe for the standard cars about 5??? I think the FPV cars are up around 7. It gives you more feel through the wheel. Works very well with stiffer springs and stiffer anti-roll bars so I wouldn't be going any lower than 7 - just upgrade the rest of your front end to suit and you'll feel a big improvement in handling.
