Max Power Member 381 Member For: 21y 15d Location: MENAI, NSW Posted 25/02/05 01:22 AM Share Posted 25/02/05 01:22 AM Got some 19s today and it looks like it can do with a bit of lowering.I did a search and reading through all the results found that SL fronts and SSL rear King springs is what members are doing. As Ive got a 'tricky' driveway, I was hoping that someone with this combo can provide centre cap to wheel arch measurements for the front and rear so I can see if I can go the same heights and avoid scraping. Anyone?How about alternatives to the King springs?Recommended places to supply and fit in Sydney?Regards,Max Link to comment https://www.fordxr6turbo.com/forum/topic/15960-ride-height-changes/ Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 9m 12d Gender: Male Location: Newcastle Posted 25/02/05 01:30 AM Share Posted 25/02/05 01:30 AM I've got King's SL's front and SSL's in the rear and the measurement between the centre cap and the guard is approx 345mm front and rear. This is only a guide line and may vary depending on the vehicle. Link to comment https://www.fordxr6turbo.com/forum/topic/15960-ride-height-changes/#findComment-224188 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 3m 4d Gender: Male Location: Sydney Posted 25/02/05 02:02 AM Share Posted 25/02/05 02:02 AM Max,How much did it raise the car ?The reason I ask is I need to raise my car as I scrape going into my driveway with 17" and stock suspension, but I need to go up about 15mm and some 19" sound better than new springs. Link to comment https://www.fordxr6turbo.com/forum/topic/15960-ride-height-changes/#findComment-224197 Share on other sites More sharing options...
Cro Flower Power Lifetime Members 6,114 Member For: 22y 7m 8d Gender: Male Location: Sydney Posted 25/02/05 02:06 AM Share Posted 25/02/05 02:06 AM Max,How much did it raise the car ?The reason I ask is I need to raise my car as I scrape going into my driveway with 17" and stock suspension, but I need to go up about 15mm and some 19" sound better than new springs.<{POST_SNAPBACK}>I'm really biting my tounge here Mal From memory, the last time I saw Mick's T (or anyone's seen Micks T) he had about the same ride height as a standard car with 19's and king springs.Might be the answer to you're question Link to comment https://www.fordxr6turbo.com/forum/topic/15960-ride-height-changes/#findComment-224199 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 3m 4d Gender: Male Location: Sydney Posted 25/02/05 02:31 AM Share Posted 25/02/05 02:31 AM Thanks Cro,I know what happend last time I mentioned Raising the T, but my fat arse has caused the sprins to sag more, so my car really scrapes bad. I need to get something done about it....and jackhammering my driveway is not an option, as has been suggested in the past I just need 10-15mm, and my wife knows that all I need is new springs....I did try to ask for Koni's, anti roll bars and new stiffer springs, but she is one smart chick and said NO CHANCE. Link to comment https://www.fordxr6turbo.com/forum/topic/15960-ride-height-changes/#findComment-224219 Share on other sites More sharing options...
Cro Flower Power Lifetime Members 6,114 Member For: 22y 7m 8d Gender: Male Location: Sydney Posted 25/02/05 02:38 AM Share Posted 25/02/05 02:38 AM Not sure how much 19's would raise it, but could be you're answer as it will raise it a bit Link to comment https://www.fordxr6turbo.com/forum/topic/15960-ride-height-changes/#findComment-224223 Share on other sites More sharing options...
Max Power Member 381 Member For: 21y 15d Location: MENAI, NSW Posted 25/02/05 03:25 AM Author Share Posted 25/02/05 03:25 AM The 19's havent raised it at all from the 17's. Ive got 245/35 on the front and 275/30 on the rear. IMO the bigger wheel and smaller tyre accentuates the height of the wheel arch which therefore needs to drop a bit.Max Link to comment https://www.fordxr6turbo.com/forum/topic/15960-ride-height-changes/#findComment-224251 Share on other sites More sharing options...
igsta Member 371 Member For: 21y 7m 9d Gender: Male Location: Sydney Posted 25/02/05 06:10 AM Share Posted 25/02/05 06:10 AM My 19 inch wheels raised my car about 10mm before I lowered it. Link to comment https://www.fordxr6turbo.com/forum/topic/15960-ride-height-changes/#findComment-224331 Share on other sites More sharing options...
69FPV Member 48 Member For: 20y 3m 29d Posted 25/02/05 06:48 AM Share Posted 25/02/05 06:48 AM My 19 inch wheels raised my car about 10mm before I lowered it.<{POST_SNAPBACK}>Me too! Link to comment https://www.fordxr6turbo.com/forum/topic/15960-ride-height-changes/#findComment-224353 Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 7m 8d Gender: Male Location: NSW Posted 25/02/05 08:05 AM Share Posted 25/02/05 08:05 AM I've put my 19's next to my 17 and the 19's are taller. They are also bald. Link to comment https://www.fordxr6turbo.com/forum/topic/15960-ride-height-changes/#findComment-224395 Share on other sites More sharing options...
