January 19, 200521 yr #1 I was just wondering how accurate G Tech timers are and would there times and figures be creditable to quoteCYA JEFF
January 19, 200521 yr #2 I was just wondering how accurate G Tech timers are and would there times and figures be creditable to quoteCYA JEFF <{POST_SNAPBACK}>As opposed to what.... :lol: :lol:
January 19, 200521 yr #3 The G-Tech is accurate but you have to ensure that the road is perfectly level, the G-tech is mounted correctly and your car does not raise its nose under acceleration all of which would give a false reading.
January 19, 200521 yr #5 The G-techs are very accurate - it doesn't matter about the nose rising during accelleration as long as it is properly levelled at set-up. This is the hardest thing to control as they are very sensitive.Also great for measuring lateral Gs if you want to do a control test on tyre grip when cornering ...
January 19, 200521 yr #6 I was just wondering how accurate G Tech timers are and would there times and figures be creditable to quoteCYA JEFF I saw your nick on Ebay.What results did you get?
January 20, 200521 yr #7 We've got a g-tech and it's pretty much spot on. I was getting 14.7's on gtech and 14.6's at Willowbank raceway.Road has to be reasonably flat, but the ones I've tested the gtech on are far from perfect.
January 20, 200521 yr #8 I would like to see some one have a few runs at a strip with the G-tech in place, then compare.I know each set-up would be different, but if its with .10 each time, at least you can get an idea if a certain mod or lauch technique is working or not.My $00.02 worth
January 20, 200521 yr #9 Author I was just wondering how accurate G Tech timers are and would there times and figures be creditable to quoteCYA JEFF <{POST_SNAPBACK}>I saw your nick on Ebay.What results did you get?<{POST_SNAPBACK}>$86 I got it today but cant test it as its raining
January 20, 200521 yr #10 I would like to see some one have a few runs at a strip with the G-tech in place, then compare.<{POST_SNAPBACK}>This has been done and the results were posted on this site a few months ago but I can't remember by whom ...The results were within 1% accuracy if I remember correctly.
