Edit
Featured Replies
#1
Ok prior to ordering the edit I need to let the distributers here in WA know what tunes I want in the little box of tricks. Bearing in mind that the maximum rwkw on offer will be a safe 240 ish
So the question is what should I be asking for?
1. Limited tune - Speed / rev. limited for the untrustworthy
2. Torque - Designed to provide more torque down low rather than outright KW up top.
3. Modded Tune - Designed to benefit centre muffler, CAI etc.
4. Ultimate fuel effeciency etc. etc.
Within each tune things such as Auto change points, A/F ratio, rev. limiter etc can also be played with.
Input would be greatly appreciated!! :spoton:
Steve
#2
remember 1 will always be your stock tune!
#3
capa said they dont come with a stock tune rather when you upload one of the programs the stock tune replaces it
#4
<{POST_SNAPBACK}>
this should be varified by tuna but the way it was described to me was the box has enough memory for 4 tunes:
1 room to upload your std tune and vehicle id
2,3&4 suplied or custom tunes
that's my understanding anyway!
#5
I understand dw
different people I talk to have different storys
how I understand it is
as I stated when you upload the mod tune it is then replace with the tune that is in the car
time will tell
#6
Do we know what price range the Edit is going to be yet?
I'm just on hold till I see how good it is.
B.B.
#7
will u still have to change things such as injectors with the edit?
#8
<{POST_SNAPBACK}>
no.. u never did but the bigger injectors (like all other mods) provides more room for extra horses! :spoton: :lol:
#9
all I meant was when u use a unichip only the injectors are maxed at 280kw so would u need bigger ones for edit to make power
#10
If you get too much torque down low,more tahn likely you wil be replacing gearboxes fairly regularly.... :spoton:
Recently Browsing 0
