  • FPV521
  • Member For: 20y 8m 26d
The throttle responce is tops on the N/A now, hows the turbo doing?
CAPA do 80mm I don't know but I think its only for the XR8 (don't even think it would fit the XR6)
Turbo is going really well. I think I was the first XR Turbo owner in NZ that had the SS induction work done and it has made a big difference. I was a bit cautious but I couldnt help it. Responsiveness has improves a lot and power has increased a fair bit to.
They claim fuel ecomomy improves as well but I wouldnt know about that. You dont drive a XR turbo or and XR8 if fuel is a problem.
Gavin
  • Replies 24
  • loitering with intent
  • Member For: 21y 9m 13d
Gavin , if you haven't already make sure you add a Hi flow panel filter, KNor BMC will do the trick . You will notice a difference with this as well. :blink:
I was running SS induction and BMC filter prior to the Phase 2 install. Definately breathes better
  • FPV521
Hi,
Yip have done the filters. Any thoughts as to what are better out of BMC or K+N or are they pretty much the same?
Gavin
  • FPV521
:blink: I've got the same induction kit on my T, with a K&N filter.
Makes a huge difference
What about high flow injectors and fuelk pump. Does that make that much of a difference?
  • Dark Knight Mafia Member No. - 666
  • Member For: 22y 3m 6d
not untill after you put a piggyback chip on it, and even then the fuel pump is still ok, did you get a higher flowing cat with your exhaust? If not would be the next thing I would do, then the chip and possibly a better design down pipe from the turbo.
Dazza
  • FPV521
:sleepystuff: I've got the same induction kit on my T, with a K&N filter.
Dazza
Hi,
Did get the hi flow. Will do chip when warranty runs out.
Whats the best chip to use?
Gavin
  • Member For: 21y 9m 11d
I put the SS insuctions Throttle Body onto my turbo, and I cant say I really noticed any difference!! When I get my valve springs done I will get the car redynoed and see if their is a decent increase in KW I guess??
  • FPV521
Did you do the air intake, filters and exhaust at the same time?
