  • Member For: 22y 5m 19d
Posted
Guys
I was wondering were was the best place to get permanent power
for a new amp??
If it is from the battery what is the best way to connect??
Also were did you run your accessory wire from??
thanks
Cragin
  • Member For: 23y 3m 23d
Posted
You should be able to run your power cable from the battery through the clutch hole (cause you have an auto) and into the cabin. As for accessories, go to you owners manual and look up the fuse for something like the Mobile phone, or better still the premium audio amp (not fitted to ute) and use that. Anything pluged into that fuse will be activated by the ignition switch.
  • Member For: 23y 1m 21d
Posted
SO any of the power wires running to the stock amp work as an ignition wire?? weird!! Ill have to test that one out for myself! will sure save alot of headaches in wiring up an ignition switch wire!!
Posted
Hustler
I could find a ignition wire in the wiring for the orginal amp.
Anyone what is the best way to connect to the battery (permanent power)
Cragin
  • Just sit back and enjoy the ride...!
  • Legacy Donating Member
  • Member For: 23y 1m 17d
Posted
Cragin,
Go to Cro's website and read up on how he ran the power from the battery for his CB radio setup. I've done much the same for my CB unit and it works well.
Piece of advice, make sure you put two fuses on that line. One at the battery end of the cable and the other just before your unit.
Posted
All the fuses in the cabin are operated by the ignition, I tried using the ones marked as battery and they turn off when the key is off.
Just use a unused fuse slot of sufficient rating.
Posted
thanks guys
Cros info on his web page was great
