July 26, 200422 yr #1 I am wondering what brand and model # fuel injectors are used in the APS kit, or infor on any other fuel injectors available for the T. Also are fuel injectors designed to be model specific or are they pretty much a universal fit on most cars.Thanks. Darren.
July 26, 200422 yr #3 Hi Darren,The "T" injector is very specific if you want to replace it with the same type. The originals fire the fuel into each port (two cone shaped sprays) at specific angles. There are a multitude of injectors that will run quite happily in the T as an upgrade and the emissions and drivability vary with the type and size of injector selected but I personally would be using the correct Bosch twin spray units as an upgrade. There's a heap of info in the forum. Search for injectors or have a look at Geea's mods. If you still have questions, PM or ring Stef@ChipTorque. We have stock on the shelf.Lachlan
July 26, 200422 yr #5 I'm pretty sure you can use Bosch injectors part no. 0 280 155 968. Around 400cc flow rate I think and correct spray pattern for the twin cam port setup.
July 27, 200422 yr #6 I'm pretty sure you can use Bosch injectors part no. 0 280 155 968. Around 400cc flow rate I think and correct spray pattern for the twin cam port setup. Yep that's the ones l've got about time
July 27, 200422 yr #8 are they sh*ts of things to install? Not to hard to install about 3/4 hour but I would not recommend you run them on the standard computor as it would appear it can not trim the fuel flow enough.Is that right scotty. Ian
