April 27, 200422 yr #1 Heya,Curious to know if anybody had issues starting their car when she was still new? When mine is cold, it seems to take a few attempts to turn over....not sure if I'm being paranoid, and wouldn't know what to check for...Appreciate any input!Cheers.
April 27, 200422 yr #3 Mines a couple of months old now and I have NEVER had any problems starting the car. Starts basically straight away.My problems always been stopping the car, I just want to keep driving it :lol:
April 27, 200422 yr #4 You will find that if the car doesn't fire and you let the key go it will be hard to start. Hold the key till it has definately started. If you do happen to let go of the key and the car isn't running turn the key completely off and wait a few seconds before retrying.This has been my experience, both before and after my mods. :banghead: Geea.
April 27, 200422 yr #5 No real issues here, turn the key and she's on within 2 seconds.......seems normal
April 28, 200422 yr #6 What you could try to to turn ignition on for a few seconds, you will hear the fuel pump and then turn fully to start the engine, this should do the trick.
April 28, 200422 yr #7 You will find that if the car doesn't fire and you let the key go it will be hard to start. Hold the key till it has definately started. If you do happen to let go of the key and the car isn't running turn the key completely off and wait a few seconds before retrying.This has been my experience, both before and after my mods. Geea. I'm the same. except for the mods bit, I don't have any.
April 28, 200422 yr #8 You will find that if the car doesn't fire and you let the key go it will be hard to start. Hold the key till it has definately started. If you do happen to let go of the key and the car isn't running turn the key completely off and wait a few seconds before retrying.This has been my experience, both before and after my mods. Geea. Same experience as Geea here. Certain times if you let the key go too early she won't fire. When that happens the next start will fire but for the first few seconds she sounds like a chaffcutter. :roll: I'm pretty sure that there is some sort of ignition protection so you won't do any damage if you hold the key for a bit longer. :roll:
April 28, 200422 yr #9 HiI have never had a problem starting now with the unichip or before mods starts firts go every time.Cheers
April 28, 200422 yr #10 No real issues here, turn the key and she's on within 2 seconds.......seems normal What he said
