GAS41T
    2
Everything posted by GAS41T
  1. Jealousy Wow I own my one home I got an Xy Fairmont which I’ve fitted a Barra I got an FG turbo but wait for it I got an rx3 I came from gov housing...worked my ass off for this... Now the issue is the fact people post topics an all you people that bit at my comment don’t comment on posts..So as I have worked out there is a small group that are the community on this forum that only communicate to each other ...I don’t have a problem with that but I ain’t jealous my friend ....no need to comment back enjoy your forum guys an girls... thanks Keith for your comments in the past seems your all alone in this forum as your the only person to comment or encourage people to post on here .... anyways enjoy your house building forum “better homes & gardens “
  2. What a giggle a car forum but I’m showing off my house and how much money I have ... forum has lost me ...
  3. Intercooler pic Can you see it!!! I have had help from Precision Racing (joe) with what way to build and what parts to hopefully achieve 400kw + ....
  4. I also picked up a 9” diff I’ve got brand new gtho drums and brake hardware + bearings an seals ... Motive gears will be fitted 3:50 ratio I’ll put a billet pinion support with motive gear full spool with non collapsing spacer ...Finished off with CalTracs for the leaf springs... I have also fitted the drive by wire pedal I also got the std FG Turbo upgraded to a gen2 gtx 35/84rs Thanks to Turbomodpro
  5. Then I also spent time on the bootIm not a Mechanic... I also had a C4 built + converter with a power torque bellhousing Rated for 800hp Full roller bearing full manual valve body 1000hp input shaft trans brake bla bla bla cost me $5000 I have a pwr trans cooler to fit
  6. That’s enough motor show an tell... This pic is of the Tuff mount kit which came with the sway bar to allow the sump to fit...Then I’ll show my electrical work ...I had to relocate the battery to the boot and all the wires that use to go to the battery I’ve relocated to the starter motor...
  7. Valve stem sealsValve springs Also the reason I changed cams was the bf gas motor cams and rollers had scorching on them . I also replace with like new rollers ...
  8. Parts All these parts was from Dominator Motorsport Atomic cams mls 1.3mm head gasket DM head studs DM valve springs DM oil pump gears + backing plate Atomic HD timing chain atomic power str delete Permaseal gasket kit So the engine is in the cleaning process in this pic The block was checked for flatness with a metal ruler all over the deck..I used a sharpening stone to clean the deck with WD40 ...Same procedure was done to the head deck... Then I serviced the head new valve stem seals before the valves was installed...Oil pump gears was also built ...
  9. Update Engine is built ...I’m going to back track a bit ...
  10. I run these cheap ass tyres on the rear of my fg nice an soft until there bold... My car smashes tyres the way I drive so don’t see the point in running $300 tyres on the rear.. The front is where you spend the dollars to keep the nose gripped up...
  11. I have catback xforce 3.5inch with 5inch dumper On the rear ....sounds deeper an louder
  12. Update: I have ordered the Tuff mount kit , We are just waiting on the sway bar...I opened the rocker cover to find scorching on the cams an rollers... So I sourced some immaculate rollers , I ordered Stg 2 Atomic cams ....I also have ordered all my parts from Dominator I highly recommend Michael is a great bloke to deal with an he saved me $$$$.... So I have Dominator valve springs, billet oil pump gears with backing plate , headstuds & valve tool... also Dominator deals Atomic so got my cams for $855 , I’ve also got atomic HD timing chain an atomic power steer delete...Dominator also helped me with a full gasket kit a MLS 4layer 1.3mm head gasket to a new water pump ...So big shoutout to Michael DOMINATOR MOTORSPORT ❤️ I also have a plazmaman intercooler and I have a 12psi turbosmart accuator on its way ... So I have also ported the flapper hole on the Garrett to help hold boost a bit better I hope... So I’m waiting to receive all of the parts to start piecing it all together fun times ahead.... I have also made contact with Bill Hooton for the electrical side of the build he makes the stand alone looms for all conversions again great bloke to speak to and a gentle man willing to help with questions.... I will take some pics very soon
  13. Progress ; I have the 2006 bf motor...Now to start stripping the crap of it... Now look at it.... I have a torque power bell housing to pick up tomorrow for the C4 ....I have a FG turbo an Exhaust manifold plus I have an FG fuel rail with 1000cc kpm injectors ...I’m waiting to fit the motor in the engine bay to see my options for intake manifold...Happy days...
  14. Fpv suspension + brembos mine also has auto trans cooler upgrade it’s a 2010 ex NWM Highway patrol ...Mine also had wear marks from holster + a couple of holes hear an there from lights computers ect...They never drove it like I do but
  15. Great build ... not a fan of the water/air intercooler from past experience....looks to small for one !!! This was my setup from 10yr ago on a rotary.... I also had an ice box but only was efficient for drag racing ....I found soon as your engine temp climbes so does your air temps = danger ... But with E85 it maybe more efficient than 10yr ago with no e85 about good luck with your tune
  16. hey people I inherited this from my father...I’m not a v8 guy I’m a Rotary freak but have a fg xr6t with 420hp @ wheels which I’ve come to enjoy as my family car ...so I’m going to Tuff Mount a Barra in to my Fairmont but I will keep the C4 gearbox an I’m going to keep the motor scoop which I’ll fit somehow to the Barra ....Now the Fg is 400kgs heavier than the Xy, so I see an easy 11sec car in the end maybe even 10sec is on the cards... I’ll keep you all updated as I progress this build..
  17. Good stuff ...
  18. I love driving my fg zf box manually when I want to play...Then it’s also great to just leave it in drive an cruise ....auto is quicker than manuals in this case ....
  19. Precision Racing use a hub dyno.... And this is my family/everyday car My RX3 is my 600hp methanol Eating Race car so I’ve got a bit of car knowledge an dyno’s... so from 289kw to 311kw Ive now got to throttle it in second gear as to 289kw I could hold it flat in second gear an it would stay straight with a fine tail of smoke but now it smashes the tyres as I said I got to throttle it to keep it straight an damn it leaves some serious black marks all the way threw second gear and a cloud behind me...
  20. My car is a 2010 ex highway with brembo’s xr6 turbo not F6..... my mods : 100cell cat aluminium pipe upgrade turbo smart blowoff autotecnica intercooler 50mm aluminium radiator Precision Racing flow matched 1000cc injectors 3.5inch xforce cat back exhaust Turbo feed line upgrade And the most important a HOON TUNE on 98 MY CAR HAS 135000kms All that makes 311kw and it’s a dream to drive...
  21. Thanks Keith.... yes on 98oct also with std dumppipe an actuator....
  22. Hey guys had my fg tuned by INtune a year ago an it just keep stalling in traffic...now it made 289kw on 15psi and it was a very aggressive car my wife hated it.... So I make contact with PR an I chose to go to them for help ....Joe changed the injectors to there flow match ones so my new injectors from intune are now pulled and replaced waste of money, but the good news is from the first tune all I did was put a xforce 3.5catback exhaust and the PR magic...the car got tuned an to my surprise the car now makes 311kw on 12 psi but the drivability of the car is like a new car wife loves it as do I thank you Joe an Ricky @ PRECISION RACING LOVE AND RECOMMEND THIS WORKSHOP ROSSKO
  23. No jet I never said that at all... I broke the top bush off my rear cradle but it got fixed.... Suspension guys told me I needed a centre bearing, but I guess I just can’t control my right foot ...So I blame myself for the tail shaft issue... anyway Im happy with the work done .... The fog is my family car ....My race car is in the garage....haha
  24. Job done.... no problem with my rear cradle!!!! notsure what your replying to Jet.... And I will be going back to the suspension guys to fit new shocks soon enough ....car is like brand new thanks to Mt Druitt Suspension & KCDR DRIVELINES ........ Rossko
