Everything posted by 1234me
How Can We Make Our Cars Lighter?
you could do all that and have a swiss cheese car or you can just add an extra 1 psi to the boost level and be quicker with all the weight.
- Advice
Xr6t Tramps When Spinning
what tyres are you using
Transmission Upgrade
the T is ideal for towing as it has a heap of mid range torque. Yes I agree the 4 speed is a little dated but from what I know it can be fixed with either a hi stall for quick takeoffs or diff ratio change for more flexability in gears. The best thing to do is get an edit and see how you go.
Most Restrictive Pipe
who can supply a direct repacement in adelaide and what is it worth?
I have a wog cooler fitted with standard piping. which pipe is the most restrictive in this setup. what advantage will there be if I change this pipe?
Standard Fuel Pump - Limit!
can I run a surge tank and bosch 044 with a standard in tank pump? is a surge tank necesary if I put a walbro gss341 in tank?
Diff Ratio Swap
Just want to know what the average price for 4.1 ratio. I have received a quote for $1300 supply and fit. is this an average price? what is labour worth on a job like this?
I have a ba auto ute and it is currently tuned to 309 rwkw I am running standard fuel pump. Is this ok ar should I change it. What is the limit on these pumps?
Diff Ratio ?
I have a 4 speed auto ute. I have been told that the 3.9 gears are not avaliable. Is this true? what would be the RPM in 4th gear @ 100kmh with the 4.1 gear set? also what would be max speed with 1st (at the moment it is 80 kmph)
Tissue Box - Fold Out Touchscreen
I was going to do this to mine but I hated the idea of not being able to have it in park when it needs to fold in and out as it is automated with the ignition. The only other way I saw was to put a double din TFT down there but it looks too low and not very practical, so I ended up selling my kenwood dvd which was only a few months old.
For 3 grand I can do you a Kewish strengthened box on an exchange basis, including tempering of the gear sets (prevents broken teeth), and a Dominator hi-stall converter. I just finished fitting one of these for member Kezza on Saturday, so PM him on how it feels if you like. Cheers ← I am in adelaide where are you?
they are in adelaide, Looking around $2600 for 3000 hi-stall and strengthen
anybody here used modbury automatics to get their 4 speed auto strengthened. If so, are you happy with the result.
8lb Actuator
I am after an 8 pound actuator, where is the best place I can get one in adelaide for a good price?
Need More Poke
I feel like I am missing on alot of fun that people are having with the zf 6 speed. I have the auto 4 speed and having first go to 80kmh is getting boring. I have over 300rwkw and would like some low down poke. I like the idea of redlining 1st and being just over 60km/h, that must feel awesome. what can I do to improe the poke down low. I know I can put better diff gears but this will effect hwy driving. what speed will 1st do if I had 3.9s and what rpm will I be at when doing 100kmh will economy be better or worse and by how much if anyone out there has changed diff gears on a 4 speed please tell me how it went.
What Time Should I Run
I have just had my car tuned. I am happy with the result but I would like another opinion with the dyno printout. Is this curve normal. Boost apparently is at 12 psi and Im not sure what torque is at.
Stall Converter Ba Ute
can anyone give me an aprox price for a 3000 stall and labour to fit it, just want to know what its worth.
What is a good street stall converter to have for the 4 speed auto and how do they behave on the freeway. I also heard that stall converters don't work in the utes due to ecu errors. how much better is having a stall converter
0-100
just went out to do some more 0-100 gtech times, best run of 4.56 sec considering I have cheap Chinese tyres on the rear I think its ok.
all mods cost me just under 4K I do have a 24000 btu trans coller to help keep the tras together So I am pretty much on the limit of everything! who can build a good trans in adelaide
4 speed auto
How Much Power Is Enough !
just want to see what most people think is ideal power for the street
What Times Are Peeople Getting With
with 260 at the treads I went to 100 in 5.45, in my auto ute with 309 I did it in 4.8 on a very hot day
I have the following mods wog cooler deka injectors cobra valve springs k&n typhoon CAI 3" metal cat (magnaflow) the car currently puts out 309 rwkw what would be the next step without spending too much what is the limit on the pistons and rods in these motors? I want to try to keep the stock exhaust as I dont like noisy cars
