February 21, 200719 yr #1 I have a 4 speed auto ute.I have been told that the 3.9 gears are not avaliable. Is this true?what would be the RPM in 4th gear @ 100kmh with the 4.1 gear set?also what would be max speed with 1st (at the moment it is 80 kmph)
February 21, 200719 yr #2 The ratio is 18% lower so max in first would be 65kph. what rpm does it do at 100kph in 4th gear lockup at the moment? Just take 18% off that.... I personally think 4.1's would be too low for a 4spd auto. i think you'd be better off with 3.7's
February 21, 200719 yr #4 not true you can get 3.89's←From who?CYA JEFF Edited February 21, 200719 yr by DBOSS
February 21, 200719 yr #5 not true you can get 3.89's←yeah, I'm with Jeff, from where?? I was told that it was not possible
