headlights
Featured Replies
#1
I have a 2012 g6e turbo with the factory headlights ,I tried the led dip globes but was not happy with the result so I fitted exellite 55 watt h7 globes ,better light ,I noticed the lenses in the centre of the high beams looked a bit "Cloudy and the high beam is not the best, Question ,can I take the globes out and get a cleaning cloth in there and clean the lenses.
the other issue is the headlight adjuster on the left-hand side does not work, is there a fix rather than replacing the whole headlight .
If I do decide to replace the headlight units, is there a preferred one to buy I want to have the best light available as I live in the country and do long hard trips, and quite often at night all replies will be greatly received
#2
You can clean the globes as long as you wipe any residual cleaner off with a clean non-residual-leaving cloth and let it dry completely before putting them back in.
For the adjuster on the left-hand-side, it depends what's wrong with it whether you need to replace the whole headlight or not...
If you want aftermarket replacement headlights are totally fine. Just have a search around for replacements.
Recently Browsing 0
