September 15, 20251 yr #1 Hello I need help. When sitting in neutral and reving up the car at 2500rpm it begins to make a rattle sound from the front of the engine, might be directed to the front left side of the motor. Nothing on idle and seem to quieten down any higher in rpm. I have taken off the rocker cover and connect se anything apparent from the top. The top of the guides look intact and there is tension on the chain at tdc. I have zero clue if this can be an issue with the cam gears or maybe the tensioner is failing ect. Cant se any rub marks on the rocker or chain. Please help me if you have any clue or have been in same position
September 15, 20251 yr #2 My guess is you've got engine mount issues and it's causing something to rub that's not meant to which is also vibrating/rattling.
