007BFXR6TURBO New Member 1 Member For: 4d Posted 25/06/25 10:01 AM Share Posted 25/06/25 10:01 AM Hi All, I'm experiencing the speedometer cut out while driving. Currently, the car is a weekender and doesn't get used on the weekdays. I started experiencing this issue when I was driving and I pushed the car hard of the line and revs needle will work, but the speed needle will cut out. I have been able to turn the car off and start it back up and drive normal and I do not experience any issues with the speedo needle working again. I have tried to push the car off the line at different intervals in relation to the acceleration force. When driving normal from a stand still its fine, then upping the intensity by 10 percent increments it is okay. I have pushed it gradually to about 50-60% acceleration. I have noticed when I go harder than that or like a heavy foot where I'm asking the car to pick up speed instantly, is when the speedo cuts out. On the cluster, the ABS and ETC light appear for the inital few seconds when the car is picking up speed and then dissappears, not sure if that is a signal to a related problem or problem identifier. Would anyone know what may be causing the speedo to cut out or where to begin with troubleshooting the problem? Thanks guys. Link to comment https://www.fordxr6turbo.com/forum/topic/97433-speedometer-cutting-out-on-bf-mkii-xr6-turbo/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,578 Member For: 17y 2m 19d Gender: Male Location: Melbourne Posted 26/06/25 09:45 AM Share Posted 26/06/25 09:45 AM that's a pretty weird issue... something to do with the throttle wiring, I guess? Any trouble-codes? Link to comment https://www.fordxr6turbo.com/forum/topic/97433-speedometer-cutting-out-on-bf-mkii-xr6-turbo/#findComment-1726440 Share on other sites More sharing options...
