fordwagonba New Member 1 Member For: 7m 30d Posted 30/08/23 05:24 AM Share Posted 30/08/23 05:24 AM Hi everyone, I have a ford falcon wagon it's a BA XT Petrol/LPG motor. I've got everything to turbo it and then some...(ARP headstuds, crow cam valve springs, billet oil pump gears, atomic head gasket). I can not find what con rods it has in it. If anyone can shed some light. If it has the weaker rods and not the same as the green top. What would be the max recommend PSI to run through it. Car will be used as drag car and maybe burnout car. Never on the road. TIA Bobert Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,317 Member For: 16y 19d Gender: Male Location: Melbourne Posted 30/08/23 05:29 AM Share Posted 30/08/23 05:29 AM If it's an LPG motor it'll have the 06/06 conrods (same as the "green top"), which are reasonable, but not great, especially as a burnout/drag car. If you're going far enough to install oil pump gears and a head gasket, you may as well upgrade the pistons and conrods while you're at it. Link to comment Share on other sites More sharing options...
