  • New Member
  • Member For: 5y 6m 1d
Hi Guys
I have a FG XR6 turbo, problem is when its cold the car has trouble starting. Sound's like the starter motor loses power then regains it in a split second. Does this for a little while until finally (5 seconds) the motor actually turns over and is firing.
No issue at all starting the car up while it's warm, it also drives smooth as silk (cold or hot) Battery is now brand new, made no difference.
Any Ideas??
  • Member For: 21y 10m
Lead acid in cold weather will be dull anyway but it's an easy check for current draw with a clamp or multimeter with the car locked...
Sounds like it might not be holding fuel pressure over extended periods which would be why hot starting is good, otherwise if the car has been tuned then it may need some attention for cold cranking.
That's my 2 cents
