fox1972 Member 47 Member For: 6y 7m 6d Posted 22/02/23 09:43 AM Share Posted 22/02/23 09:43 AM Hi everyone.... I have a BA Series II XR6T with the standard suspension...nothing modified. I'm shortly about to purchase some 19 inch Vertini magic concave wheels (as soon as their back in stock). Available widths are 8.5, 9.5, 11. I can pretty much choose what offset I want. My question is....what width and offset should I run on the front and the rear. I want it to look sporty but neat and clean looking...after all...I am 50. Regards.. Link to comment https://www.fordxr6turbo.com/forum/topic/96914-new-wheels-for-xr6tneed-advice/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,503 Member For: 17y 1m 7d Gender: Male Location: Melbourne Posted 22/02/23 02:27 PM Share Posted 22/02/23 02:27 PM I think 19x8.5+38 is best for the fronts and should fit reasonably well and potentially no guard work at stock suspension height. e.g. https://www.willtheyfit.com/index.php?width=245&aspect=45&diameter=17&wheelwidth=8&offset=36.5&width2=245&aspect2=35&wheel_size=19&wheel_width=8.5&offset2=38 19x9.5+45 for the rear and should fit without guard work , especially at stock height e.g. https://www.willtheyfit.com/index.php?width=245&aspect=45&diameter=17&wheelwidth=8&offset=36.5&width2=245&aspect2=35&wheel_size=19&wheel_width=9.5&offset2=45 Here's the measured clearances from when I changed the wheels from OEM 17x8's on my BA. Your measurements should be about the same. With the above offsets yours should fit no worries... just the fronts might need some guard work if they foul a bit on turning at full suspension travel. On 08/08/2022 at 1:48 PM, k31th said: Front Inner: ~9mm Front Outer: ~15mm Rear Inner: ~30mm Rear Outer: ~15mm Link to comment https://www.fordxr6turbo.com/forum/topic/96914-new-wheels-for-xr6tneed-advice/#findComment-1717459 Share on other sites More sharing options...
