Lerm New Member 11 Member For: 4y 1m 20d Posted 21/02/22 06:26 AM Share Posted 21/02/22 06:26 AM So I bought a 2014 xr6 turbo a month ago and for a while I had a rattling noise from the engine bay on idle and have just realised it also rattles when at low rpm (cant hear much at mid-high rpm due to the exhaust). I can really only hear the rattling noise when sitting in the drivers seat with the window down, I just had the idler pulley, pulley tensioner and drive belt replaced because I thought that was the issue but its still there. Any help would be appreciated as it doesn't sound good at all. Mods (all done by previous owner): 1000cc injectors 3.5inch turbo back exhaust with 4 inch cat and mid muffler delete fuel pump (unsure what fuel pump) 1000hp rated intercooler battery relocation/turbo side intake braided turbo oil line NPC twin plate clutch 1000hp rated tuned to 327rwkw Link to comment Share on other sites More sharing options...
cat007 Member 234 Member For: 5y 7m 23d Posted 21/02/22 06:32 AM Share Posted 21/02/22 06:32 AM Auto or manual? Could be flex plate if auto. Link to comment Share on other sites More sharing options...
Lerm New Member 11 Member For: 4y 1m 20d Posted 21/02/22 06:36 AM Author Share Posted 21/02/22 06:36 AM Its a manual forgot to add that to the post. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,310 Member For: 16y 17d Gender: Male Location: Melbourne Posted 21/02/22 06:36 AM Share Posted 21/02/22 06:36 AM it says "NPC twin plate clutch" ... it's a manual... that being said, all twin plate clutches rattle around a bit when they're in neutral... Does it happen when you're sitting still and changing the revs? or does it only happen when you're rolling/driving? Link to comment Share on other sites More sharing options...
Lerm New Member 11 Member For: 4y 1m 20d Posted 21/02/22 06:40 AM Author Share Posted 21/02/22 06:40 AM It happens when sitting in neutral and taking off from what I can hear, the exhaust is too loud for me to hear if it happens while driving. Link to comment Share on other sites More sharing options...
Lerm New Member 11 Member For: 4y 1m 20d Posted 25/02/22 05:58 AM Author Share Posted 25/02/22 05:58 AM B Link to comment Share on other sites More sharing options...
cat007 Member 234 Member For: 5y 7m 23d Posted 26/02/22 01:58 AM Share Posted 26/02/22 01:58 AM Clutch thrust bearing? Or spigot bearing perhaps? Link to comment Share on other sites More sharing options...
Lerm New Member 11 Member For: 4y 1m 20d Posted 30/03/22 08:54 AM Author Share Posted 30/03/22 08:54 AM Could it be one of those things if the sound happens when the clutch is engaged and disengaged? Link to comment Share on other sites More sharing options...
