Raptor_Z Member 43 Member For: 5y 5m 6d Posted 19/12/19 09:47 AM Share Posted 19/12/19 09:47 AM Hi fellows This message pops on my dash “TRANSMISSION FAILURE” with sometimes transmission dies and don’t engage anything and I have to put it into shift mode to drive or have to switch the ignition off and on to drive, has anyone had that issue before and fixed it? would really appreciate if someone can reply no milkshake thing though and I have serviced the tranny too 2010 Zf6 Auto cheers Link to comment https://www.fordxr6turbo.com/forum/topic/95383-zf6-%E2%80%9Ctransmission-failure%E2%80%9Dauto/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,515 Member For: 17y 1m 15d Gender: Male Location: Melbourne Posted 19/12/19 09:54 AM Share Posted 19/12/19 09:54 AM weird sporadic messages that are fixed via Key-Off-Key-On like that are often due to a failing battery or failing battery terminal connection(s). Link to comment https://www.fordxr6turbo.com/forum/topic/95383-zf6-%E2%80%9Ctransmission-failure%E2%80%9Dauto/#findComment-1690879 Share on other sites More sharing options...
Raptor_Z Member 43 Member For: 5y 5m 6d Posted 19/12/19 09:58 AM Author Share Posted 19/12/19 09:58 AM You reckon it’s something to do with the ecu computer? battery terminals are good mate Link to comment https://www.fordxr6turbo.com/forum/topic/95383-zf6-%E2%80%9Ctransmission-failure%E2%80%9Dauto/#findComment-1690880 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,515 Member For: 17y 1m 15d Gender: Male Location: Melbourne Posted 19/12/19 10:03 AM Share Posted 19/12/19 10:03 AM no, it doesn't sound like an ECU issue. just get the battery tested. then next step is to run it up on a dyno to see if you can replicate it with logging to figure out what sensor might be failing if it's a sensor. Link to comment https://www.fordxr6turbo.com/forum/topic/95383-zf6-%E2%80%9Ctransmission-failure%E2%80%9Dauto/#findComment-1690882 Share on other sites More sharing options...
Raptor_Z Member 43 Member For: 5y 5m 6d Posted 19/12/19 10:13 AM Author Share Posted 19/12/19 10:13 AM will do that mate It Revs high in second gear when I put it on the shift mode after it dies but no thud though, it does probably once a week just curious if anyone here had the same message on the dash and fixed it? Link to comment https://www.fordxr6turbo.com/forum/topic/95383-zf6-%E2%80%9Ctransmission-failure%E2%80%9Dauto/#findComment-1690883 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,515 Member For: 17y 1m 15d Gender: Male Location: Melbourne Posted 19/12/19 10:15 AM Share Posted 19/12/19 10:15 AM yeah, if it's not "revving high" in a gear while you're on full throttle, then it's likely your transmission is perfectly fine and it's either a sensor or an electrical connection (e.g. the stuff I talked a bout above). Link to comment https://www.fordxr6turbo.com/forum/topic/95383-zf6-%E2%80%9Ctransmission-failure%E2%80%9Dauto/#findComment-1690884 Share on other sites More sharing options...
Raptor_Z Member 43 Member For: 5y 5m 6d Posted 19/12/19 10:20 AM Author Share Posted 19/12/19 10:20 AM Great thanks mate I might just take it to the tranny shop 😊 Link to comment https://www.fordxr6turbo.com/forum/topic/95383-zf6-%E2%80%9Ctransmission-failure%E2%80%9Dauto/#findComment-1690885 Share on other sites More sharing options...
Raptor_Z Member 43 Member For: 5y 5m 6d Posted 20/12/19 10:56 AM Author Share Posted 20/12/19 10:56 AM Ok so The transmission fault comes on in about 80ks for about 20 mins into the drive, can't change gears or anything it goes into manual mode and can't do anything to the car unless you switch it off and on so basically it goes into “limp mode” now what are the solutions for this issue, anyone fixed it or had that problem in zf6 Link to comment https://www.fordxr6turbo.com/forum/topic/95383-zf6-%E2%80%9Ctransmission-failure%E2%80%9Dauto/#findComment-1690897 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 27d Gender: Not Telling Posted 21/12/19 12:20 AM Share Posted 21/12/19 12:20 AM As keith said it sounds electrical. A shop can check the fluid level and condition for peace of mind but if you haven't had your battery checked I would highly recommend it. I had an issue in mine fixed by changing the ignition coils for example (not saying yours are at fault). Link to comment https://www.fordxr6turbo.com/forum/topic/95383-zf6-%E2%80%9Ctransmission-failure%E2%80%9Dauto/#findComment-1690905 Share on other sites More sharing options...
Raptor_Z Member 43 Member For: 5y 5m 6d Posted 21/12/19 09:36 PM Author Share Posted 21/12/19 09:36 PM The transmission just recently serviced I will definitely check the battery mate and scan for the fault codes too any good scanning OBDII tool? Link to comment https://www.fordxr6turbo.com/forum/topic/95383-zf6-%E2%80%9Ctransmission-failure%E2%80%9Dauto/#findComment-1690921 Share on other sites More sharing options...
