  • Member For: 6y 11m 16d
Hey guys,
having problems with my dash/ instrument cluster side buttons not working. Just wanting to know if I can just straight swap the whole instrument cluster with another with within 2000hrs. Does it need to be from a exact model as mine is a series 2 bf xr6 turbo? Does this mean it needs to be from a xr6 turbo or will a N/A or xr8 still have same cluster. Also does this create any problems with BCM or security?
cheers for any advice
https://www.fordxr6turbo.com/forum/topic/95180-instrument-cluster-replacement/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 25d
A ford dealer should be able to code in any cluster that matches the physical dimensions of the fitment to your car
Ok sweet, that’s all I needed to know really whether or not it needed to be coded to the vehicle or if I can just swap it, thanks for your replies once again Keith. Truth of the matter is I have never had a engine light come up on the dash before but have had codes so got to thinking someone may have removed engine light globe, so I attempted to remove cluster to check not knowing there was screws on the bottom and thinking maybe plastic clips and I cracked the bottom of the cluster and now hazard light and dash controls on right hand side do not work anymore☹️. Maybe these are replaceable on there own than without replacing complete cluster?
  • Site Developer
well, I don't know the specifics of how that connector works or how the clips you broke interface with the electrical connection, but it'd probably easier to patch up a dodgy repair for those than to stuff about with a replacement cluster.
  • Dropping a turd
  • Member For: 17y 6m 8d
Three screws top.  Two bottom. If you get a cluster from a bf2 it will work. Even BF1 may work.  V8 or 6 doesnt matter.  Auto or Manual   No recoding.
But you need to get low series or high series. If your trip button is on the side buttons of the cluster it's low series.
Edited by arronm
