Help my xr6 turbo warriors
Featured Replies
#1
So recently I replced my spark plugs tube seals around 3 weeks ago.
I had a missfire again on idle(ready to burn the ****) just removed first 2 plugs and oil covered them both rest were fine. Pulled rocker cover off cant see anything out of unusual I used aftermarket tube seals hoping that's not the problem maybe I need to buy ford ones.
Car doesnt misfire on driving just idle.
Ps this was with in 2 weeks of changing them.
I hope its not an engine problem
#2
Are you sure it's not the vct seals leaking? I had the same issue and it was those not the spark tube seals.
#3
  • Author
Hey mate thankyou for replying ive got them on fairly tight I did think that, I was worried about like bad oil control rings im not a mechanic but I know a bit. The bolts were undone and loose when I checked, id like to rule out no engine failure
#4
I'd clean it all up, put it back together and go for a quick drive around the block and see if it starts leaking again
#5
  • Author
I think u hit the nail on the head though :)
Recently Browsing 0
