JETLAG New Member 6 Member For: 8y 10m 5d Posted 23/08/17 10:17 AM Share Posted 23/08/17 10:17 AM Hey guys. I'm sure this has been asked and answered before but I can't find much about it so posting again. Bit of back story. I have a 2010 fx6 xr6T. Done about 110k. For the last few months I have had a knock in the front end. Sounds to me like it's coming from the front right. I can feel it through the pedals and through the foot well. I have a slight vibration in the steering wheel also. I have replaced springs all round and shocks in the last month. Upper control arms and sway bar link pins and the knock is still there. Have had it looked at twice. First time telling me it was shock/ control arm bush so have replaced them. Second was a maybe sway bar links as no other obvious issue. Can someone please help me out with some other possibilitiesas at the moment I'm about to start changing things just for the fun of it. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/93449-fg-front-end-knock/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 9d Gender: Male Location: Adelaide Posted 23/08/17 10:20 AM Share Posted 23/08/17 10:20 AM Front sway bar top 13mm bolt, give it some love and let me know Link to comment https://www.fordxr6turbo.com/forum/topic/93449-fg-front-end-knock/#findComment-1644019 Share on other sites More sharing options...
JETLAG New Member 6 Member For: 8y 10m 5d Posted 23/08/17 10:43 AM Author Share Posted 23/08/17 10:43 AM When you say top bolt are you refering to the link pin? There is 4 that go up from underneath that hold the sway bar to the vehicle but not sure about any others apart from the link pins which I changed last Thursday so I know they are sweet. I also should have mentioned that the sound is only noticeable when turning left or at high speeds. Doesnt seem to matter if I'm braking or not and the harder I take the corner the worse it is. Also does it at high speeds going straight if it's bumpy enough 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93449-fg-front-end-knock/#findComment-1644021 Share on other sites More sharing options...
kink Member 294 Member For: 16y 11m 5d Gender: Male Location: Adelaide Posted 25/08/17 08:02 AM Share Posted 25/08/17 08:02 AM Howd you go Jetlag, any progress? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93449-fg-front-end-knock/#findComment-1644098 Share on other sites More sharing options...
JETLAG New Member 6 Member For: 8y 10m 5d Posted 26/08/17 12:35 AM Author Share Posted 26/08/17 12:35 AM 16 hours ago, kink said: Howd you go Jetlag, any progress? Hey mate not yet. Was in darwin for trade school so took it to a workshop up there but apart from saying the lower control arm bushes are a bit warn they weren't able to find it. ( the infamous didn't make the noise when they test drove it trick ) but I'm home now so will jack it up today or tomorrow and have another look and go from there. Will be ordering the new lower control arm bushes and swapping them anyway 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93449-fg-front-end-knock/#findComment-1644111 Share on other sites More sharing options...
Gee-dog Member 27 Member For: 11y 3m 2d Posted 26/08/17 10:38 AM Share Posted 26/08/17 10:38 AM Do you have poly bushes on the caster arms? Mine are Superpro (I think) and came with large steel washers that go either side of the bush. On my 09 FG one of these washers was catching on the body mount, causing a clunk whenever the caster arm moved a bit - ie turning, braking etc. A couple of suspension places couldn't find the cause - gave me the sh*ts for over a year before I found what it was. Link to comment https://www.fordxr6turbo.com/forum/topic/93449-fg-front-end-knock/#findComment-1644129 Share on other sites More sharing options...
