  • Member For: 13y 9m 3d
hi all
im half way through replacing the head bolts with studs.
chasing info on what pattern to undo the head bolts down to there first stage ill then replace each one one at a time
the arp box says to torque them down to 100 foot pounds and ill be doing that in 3 equal steps. but ive got atomic oversize washer to go with the studs so should I got a little tighter?
and what torque should I tighen the caps for the cams back to
only asking because I legit cant find the info on the net
thanks guys
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 8d
I don't recommend the method you're going about but that's up to you ;)
no it's not a spiral ( head torque sequence ) and no their ( cam caps ) not 40nm
