Fuel Guage Not Working After Bigger Pump Installation
Featured Replies
#1
hi all
I installed a bigger walbro pump bought it new complete with plastic cradle so just had to pull old pump out and pop bigger set up in now the fuel guage doesn't work I've checked to make sure that all the wiring is clipped back on and it is no leaks car drives will it work again once I have the car tuned
#2
sedan or ute?
Which wire did you check was clipped back in?
#3
  • Author
Sedan
The sender in the tank and the external one it's got me stuffed could the new one be faulty ?
#4
The sender is plugged in for sure?
If it was working 100% before and is plugged in, check the terminals on the new pump assembly for continuity.
Recently Browsing 0
