27/08/15 11:29 PM27/08/15 11:29 PM #1 STREETFIGHTER Ultimate Fuel System Upgrades For Your Ford.Do it Once , Do it Properly !Streetfighter Flex Fuel Retrofit Kits are tailor made to direct fit perfectly like OEM products.We supply every component needed to correctly retrofit your performance Ford to run both ethanol and petrol fuels.Flawless fuel system operation for power levels ranging from standard all the way up to 1500HP!Cool, dense fuel delivery at correct pressures ensures OPTIMAL POWER with NO SURGE, Guaranteed!Suits all Ford BFMK2-FGX Sedan and Ute models• KPM 1000cc/1500cc precision stainless steel fuel Injectors by Bosch• Streetfighter 1500HP Lifetime Flex Fuel Filter / 10 micron Stainless Steel• Streetfighter 400 lph stainless steel fuel pressure regulators on the 1000HP kits• Anodized aluminium adjustable 800lph pressure regulators on the 1500HP kits.• 2 x Streetfighter 10,000 hour Ethanol compatible fuel pumps on 1000HP kit• 2 x Walbro 460 Ethanol compatible pumps on 1500HP kit• Nickel plated and stainless steel fittings• Streetfighter stainless steel in tank fuel modules guarantees NO Surge!• Ethanol compatible high pressure fuel hoses with OEM fittings• Viton o rings throughout• Direct fit OEM plug and play /relay wiring kit• Suitable for both street performance and motorsport use• 100% legal , safe with no noise , smells or emissions• OEM quality, fit and operation• Comprehensive fitting instructions providedProudly manufactured in Australia to the very highest standards.Streetfighter.Nothing Comes Close! Edited 27/08/15 11:31 PM27/08/15 11:31 PM by KPM Motorsport
27/08/15 11:54 PM27/08/15 11:54 PM #2 I was tossing up between your 1700cc and the ID1700cc is there a reason you have yours flow 1700cc at 4bar where as the IDs flow 1700cc at 3bar?
28/08/15 01:21 AM28/08/15 01:21 AM #3 Author We quote 4 bar for injectors as Ford and most models run a 4 bar system. This is also where all scaling data is generated for Fords and most models.so all matches up.
