  • Member For: 12y 5d
Hi,
I got some error codes on my ba xr6t Auto,
they are:
P0238 - Turbocharger boost sensor A circuit
P0243 Turbocharger wastegate Solenoid A
P11832 - Engine Oil Temperature Sensor Circuit
P2105 - Throttle Actuator control system - forced engine shutdown.
I have just replaced the turbo after a bearing failure and also fitted a FG xr6T wastegate actuator due to damage on my old one.
https://www.fordxr6turbo.com/forum/topic/89225-ba-xr6t-error-codes/
yes codes instantly re-appear after clearing..
the only problem I have with the car is very occasionally (once every 10 days maybe?) when driving the throttle will become unresponsive, pressing it 100% does absolutely nothing, turning the car off and back on and it will be fine again.
I have access to VCM tuning software and have the ecm unlocked, we had previously raised the boost levels and played with a couple of other things, so I thought restoring the factory tune might solve this problem, but after a week of running with the factory tune it has just done this again. (I wonder if this is the forced shutdown code?)
