  • Legacy Donating Member
  • Member For: 15y 1m 23d
Posted
What fuel system are people running with 500-600rwkw on E85?
I have twin feed rail with fpr1200 -6 feeds and -6 return. Twin 044's will this setup be enough for mid 500's???
  • 2 weeks later...
  • Member For: 21y 2m 25d
Posted
What injectors are you planning on using? If you get low on pump capacity and have the injector flow you can lower the pressure to get a little more out of the 044's and they'll be good for it. Otherwise people are using the large Holley's and PW twin 460's.
  • Member For: 20y 11m 11d
Posted
We have just released our new Streetfighter Twin 460 walbro 1500HP In-tank fuel system.
As labelled this system will support over 800 rwkw on E85.
Our KPM1500cc Injectors swill support 550-600 rwkw on E85
Posted (edited)
Toads, will be using kpm1500's
Is the -6 feeds and return to small?
Edited by Kosij
Posted
Not at all.
The standard fuel rail, fuel lines and fitting can all flow over 700lph perfectly.
Posted
Consists of twin 044's fed to twin feed rail -6 lines
Then fpr1200 with -6 return to surge, then standard return to tank!
Posted
We utilise an adjustable 900lph return flow Fuel pressure regulator simply placed in series.
