  • Im the one and only
  • Legacy Donating Member
  • Member For: 21y 9m
Posted
I had an 03 turbo ute years ago and it did the same. Ended up being the wastegate actuator. Try doing the boost solinoid maintainace.
  • Member For: 12y 11m 8d
Posted
Mines doing the same thing, running rich and low boost 3.7-4psi, considering factory actuator opens at 3psi I'm guessing the solenoid is stuffed. Tried cleaning it out but no difference
  • Member For: 12y 5m 2d
Posted
How many volts if your fuel pump getting? A mates skyline was doing that same thing, turned out to be the pump was only getting 12.1 volts without lights on... Should be getting 14.
Posted
It would more than likely lean out and start detonating rather than running rich though
  • 2 weeks later...
