May 7, 201412 yr #1 I had gt sport shocks and SSL king springs installed 2 weeks ago now and have since fitted new wheels.I let these settle and they have come down around another 10mm to the photos and I noticed the front is lower than back with the exact same setup has anyone had similar issues as im scrubbing on tight turns or uneven surface. just wondering if anyone else has had the same issues or know what if anything I can do to fix the scrubbing.FrontWheel 20 x 8.5 +35 245Height 340mmBack Wheels 20 x 10 +40 275Height 350mm
May 7, 201412 yr #2 It is fairly common for the SSL springs to keep the same factory rake when used in a turbo car front and rear. The wheel and tyre combo makes it more obvious
May 8, 201412 yr #3 Yea that's why most people seem to go with a ssl/sssl combo, one lower in the rear. The king springs work on lowering the car by xx mm from factory. Because as senna said the rear sits much higher from factory you still maintain the rake
May 8, 201412 yr #4 Author I get the ride height difference and I actually like the stance but im just more worried about the rubbing on tight turns and full lock
May 8, 201412 yr #5 Worried about the front or rear? Both should be fine, rear could possibly rub and if it does nothing a slight guard roll won't fix
May 9, 201412 yr #6 Author Its only the front with the issue the back is perfect. Wonder if I should take it back to the shop.
