  • Member For: 13y 8m 23d
Hi I have a bk mkII turbo ute that has the following error codes p0243 and p0238.
One the ute I have an aftermarket intercooler and a plazaman off the turbo.
I have changed the sensor under the battery and its been at ford with no luck.
Is there something I can do or try to fix it, or does any one know some one I can take it to who is good at fixing these codes
regards
stephen
  • skids
  • Member For: 12y 5m 23d
  • Gender: Not Telling
Is the boost solenoid plugged in (I think the one u said near battery)?
Near the air box and ECU, look for the connection, it might be tucked back and hidden like mine was.
I had those two exact codes rectified by plugging it in :) And it would make more than 4psi of boost.
Otherwise an earthing problem?
Edited by johnxr6t
As in the map sensor near the head light under the battery that's plugged in. The boost solenoid is that under the battery near the turbo?
How did you fix the earth problem? If all that is plugged in?
  • skids
I'm talking about the boost solenoid which has two rubber vacuum lines attached to it and a electrical connector going to the ECU. I had those two codes eliminated by plugging the solenoid in that some noob had forgot to do - and like 5 mechanics did not find.
One day I was changing my passenger side headlight globes and found two cables tucked back and unplugged.
  • skids
Maybe yours has had a frontal impact on that side of the car similar to what my old one used to, only explanation as to why mine was tucked back.
Edited by johnxr6t
