farnzy_1 Member 16 Member For: 13y 7m 7d Posted 08/01/14 09:25 AM Share Posted 08/01/14 09:25 AM Hi I have a bk mkII turbo ute that has the following error codes p0243 and p0238. One the ute I have an aftermarket intercooler and a plazaman off the turbo. I have changed the sensor under the battery and its been at ford with no luck. Is there something I can do or try to fix it, or does any one know some one I can take it to who is good at fixing these codes regards stephen Link to comment https://www.fordxr6turbo.com/forum/topic/87238-help-i-have-a-p0243-and-p0238-code-problem/ Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 28d Gender: Male Location: OZ Posted 08/01/14 10:08 AM Share Posted 08/01/14 10:08 AM The car hasn't been tuned yeah? Link to comment https://www.fordxr6turbo.com/forum/topic/87238-help-i-have-a-p0243-and-p0238-code-problem/#findComment-1448918 Share on other sites More sharing options...
farnzy_1 Member 16 Member For: 13y 7m 7d Posted 08/01/14 10:10 AM Author Share Posted 08/01/14 10:10 AM No tune yet Link to comment https://www.fordxr6turbo.com/forum/topic/87238-help-i-have-a-p0243-and-p0238-code-problem/#findComment-1448920 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 12d Gender: Male Location: Perth Posted 08/01/14 10:26 AM Share Posted 08/01/14 10:26 AM Perhaps getting it tuned my help with the codes? Link to comment https://www.fordxr6turbo.com/forum/topic/87238-help-i-have-a-p0243-and-p0238-code-problem/#findComment-1448925 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 7d Gender: Not Telling Posted 08/01/14 11:43 AM Share Posted 08/01/14 11:43 AM (edited) Is the boost solenoid plugged in (I think the one u said near battery)?Near the air box and ECU, look for the connection, it might be tucked back and hidden like mine was. I had those two exact codes rectified by plugging it in And it would make more than 4psi of boost. Otherwise an earthing problem? Edited 08/01/14 11:44 AM by johnxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/87238-help-i-have-a-p0243-and-p0238-code-problem/#findComment-1448937 Share on other sites More sharing options...
farnzy_1 Member 16 Member For: 13y 7m 7d Posted 08/01/14 12:02 PM Author Share Posted 08/01/14 12:02 PM As in the map sensor near the head light under the battery that's plugged in. The boost solenoid is that under the battery near the turbo? How did you fix the earth problem? If all that is plugged in? Link to comment https://www.fordxr6turbo.com/forum/topic/87238-help-i-have-a-p0243-and-p0238-code-problem/#findComment-1448939 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 7d Gender: Not Telling Posted 08/01/14 12:11 PM Share Posted 08/01/14 12:11 PM I'm talking about the boost solenoid which has two rubber vacuum lines attached to it and a electrical connector going to the ECU. I had those two codes eliminated by plugging the solenoid in that some noob had forgot to do - and like 5 mechanics did not find. One day I was changing my passenger side headlight globes and found two cables tucked back and unplugged. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87238-help-i-have-a-p0243-and-p0238-code-problem/#findComment-1448940 Share on other sites More sharing options...
farnzy_1 Member 16 Member For: 13y 7m 7d Posted 08/01/14 10:30 PM Author Share Posted 08/01/14 10:30 PM No worries I'll have a look at that today Link to comment https://www.fordxr6turbo.com/forum/topic/87238-help-i-have-a-p0243-and-p0238-code-problem/#findComment-1448979 Share on other sites More sharing options...
farnzy_1 Member 16 Member For: 13y 7m 7d Posted 09/01/14 06:56 AM Author Share Posted 09/01/14 06:56 AM Thanks so much for your help it was the plug behind the headlight that wasn't plugged in. No more codes 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87238-help-i-have-a-p0243-and-p0238-code-problem/#findComment-1449072 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 7d Gender: Not Telling Posted 10/01/14 06:21 AM Share Posted 10/01/14 06:21 AM (edited) Maybe yours has had a frontal impact on that side of the car similar to what my old one used to, only explanation as to why mine was tucked back. Edited 10/01/14 06:21 AM by johnxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/87238-help-i-have-a-p0243-and-p0238-code-problem/#findComment-1449254 Share on other sites More sharing options...
